Removing rear spheres on a Xantia?
HDI
x 7
Unread post by HDI »
Can someone remind me of the procedure for removing the rear spheres on a xantia? Just the 2 suspension spheres on a basic LX model. I recall that the rams go loose if all the pressure is relieved, which means the pipes get stressed when twisting the spheres free.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 3298
Re: Removing rear spheres on a Xantia?
True. Making sure to set up axle stands (so if she does drop it is not far), get her to full height, and then get the spheres to turn about 1/8th (I have had to use a hammer and chisel to get them started). That way they are now loose enough so that you can now (with the pressure off) undo the spheres.
x 1484
Unread post by xantia_v6 »
  1. Suspension high
  2. Car on axle stands
  3. Loosen spheres
  4. Suspension to low (with engine running)
  5. Wait a couple of minutes
  6. Engine off
  7. Undo spheres
  8. New spheres on
  9. Suspension to high
  10. Check for leaks
  11. Car on ground
  12. Suspension to normal
HDI
x 7
So no need to loosen the pressure relief bolt on the regulator?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 3298
Not until you have initially cracked the rear spheres loose. Then you do release that pressure relief bolt by a turn or so.
HDI
x 7
Copy that, cheers guys.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
elma
x 284
Unread post by elma »
I find it useful to wedge a pry bar between the mount and the car to stop the sphere mount from rotating. Been a while since I was under a Xantia but theres a nice little groove in the sphere mount that seems to have been made for this.
x 8457
HDI wrote:So no need to loosen the pressure relief bolt on the regulator?
I never do when changing spheres other than the accumulator. Comes of running V6s where the bleed screw is almost inaccessible anyway...
As soon as the sphere is cracked any remaining pressure will soon dissipate...
x 3298
And, if a sphere has ruptured, it will vent LHM as far as it can (and that can be several meters).
x 8457
Hell Razor5543 wrote:And, if a sphere has ruptured, it will vent LHM as far as it can (and that can be several meters).
Yes indeed and is quite spectacular to see :D It will vent for quite some time too..
It takes on the appearance of a water pistol being quite furiously fired!
x 1504
And if you're lucky it won't rip a big lump out of the rear strut, opening up a whole world of pain.... :cry: :roll:
http://www.frenchcarforum.co.uk/forum/v ... 11&t=44218
x 3298
True, and that can also happen on a C5 strut (it has happened on one of mine, necessitating a replacement strut).
x 697
Unread post by Mandrake »
0. Spray plenty of penetrating lubricant around the sphere/cylinder junction a few hours before attempting to remove them. :lol:
xantia_v6 wrote:
  1. Suspension high
  3. Loosen spheres
  6. Engine off
  7. Undo spheres
  8. New spheres on
  10. Check for leaks
  11. Car on ground
x 2008
Unread post by Stickyfinger »
Wire brush all the crap away from the join Before you remove them.
And once you have replaced them, paint a thick coating of Waxoil (applied cold and with a small brush) all around the join.
HDI
x 7
I've done them before but it's been a while. Dead spheres spraying LHM is a familiar sight, such fun. The ones in question are being utter pigs though, they just will not loosen! I used enough force to bend the steel bracket around the rear of the ram, and it was distorting the pipe more than I was prepared to risk. So it'll be on a 2 post lift next week so I can remove the pipes to avoid breaking them, and lock the rams in place so that biblical force can be applied to the spheres!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
