Rd4 to rneg myway
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
Psaman
Rd4 to rneg myway
Unread post by Psaman »
Hi. Have uppgrade my car (citroen c5 x7 2010) whit a rneg navigation system. Everything works fine but my usb socket does not work (did work whit Rd4) this is the original usb system.
Do enny have som idea what I have to do.
x 6948
Re: Rd4 to rneg myway
iIf you've changed the unit you will need the Lexia / Diagbox to properly code the unit to your car and to configure the correct parameters for the system. Normally this would be automatically done at the factory, but there are some settings that have to be configured as default values for the system to work properly, not just the audio settings but things like the parking assistance type, tpms and display settings, volume according to speed etc. Some of these need to be done in the main BSI and others in the Audio ECU IIRC. I assume you're referring to the USB in the centre arm rest console?
Do you have your own Lexia kit as I see you are in Norway? If not you may need to find somebody with one or pay for Citroen to configure it for you.
vborovic
Locked user account
x 40
Unread post by vborovic »
RNEG isn't compatible with the USB port
x 6948
Of course - that system has the SD card for the navigation and the Hard Disk IIRC. If you want a USB, you'll probably have to get the USB Box fitted and activated or the EZDAB /AUTODAB or similar.
Psaman
Strange on some of this cars you get usb or aux in the console and this is whit rneg (1).
I see that there are some differences whit the media box that are installed.
Psaman
Hi, yes I do have diagbox :-)
I see in the schematics for cars whit rneg and aux (usb) that those cars do have maybe a different media box that's control the USB signal. If you look at peugeot 3008 it's quite common whit aux and usb on this system
Tommy
GiveMeABreak wrote:iIf you've changed the unit you will need the Lexia / Diagbox to properly code the unit to your car and to configure the correct parameters for the system. Normally this would be automatically done at the factory, but there are some settings that have to be configured as default values for the system to work properly, not just the audio settings but things like the parking assistance type, tpms and display settings, volume according to speed etc. Some of these need to be done in the main BSI and others in the Audio ECU IIRC. I assume you're referring to the USB in the centre arm rest console?
