I am looking to replace my drivers door seal ( the one that goes round the door frame ) not the one that is fitted to the door itself. I have tried nearly every where and carn't seam to find one. I am not going to Citroen as they charge you the earth,i am on pension.
C5 x7 front door seal
renagade
- x 10
Good morning to you all.
There are so many roads to travel but so little time, (Paul Cofield )
- x 6956
Re: C5 x7 front door sel
I doubt you'll get one from a breaker that is in any condition to fit once removed. If you post or pm your VIN I'll be able to give you the Citroen price for a replacement a bit later on.
Alternatively, have a squiz at this video that shows a simple way of bulking out your existing seal if it just needs that and isn't torn or ripped:
- x 1999
DHallworth
- x 167
I think these retail from Citroen at around £130. Unfortunately, it's likely to be the only place you'll get one.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1999
- x 6956
There are 2 of these for the DOOR FRAME (front & Rear) which are different to the seals that go on the door itself. It is the Door Frame ones which Renegade says he needs and these are part number 9025 E5 for the front and cost £78.70 inc. VAT from Citroen. There are generic ones you can buy - basically they just use a plastic mallet to apply over the flange - starting from the top corner.DHallworth wrote:I think these retail from Citroen at around £130. Unfortunately, it's likely to be the only place you'll get one. David.
- x 6956
I know - amazing, but probably does the job!!Stickyfinger wrote:LOL, that is a Mk1 Bodge
renagade
- x 10
Re: C5 x7 front door seal
Hey thanks guy's, I will go down to the garage and see what I can do. I don't fancy putting rope round my Citroen door frame,,,,would you ??????
Again thanks for all your input.
