Lexia -2- C2
x 1983
Lexia -2- C2
Unread post by Stickyfinger »
As my Lexia will not talk to a Berlingo, do you think it will talk to a C2 ?
x 3283
Re: Lexia -2- C2
What is the age difference between the two vehicles? You are aware that some of the PSA commercial vehicles need an extra diagnostics device to read them? I don't know if that is the case for PSA Commercial to Passenger conversions.
EDIT; It looks like the Berlingo does NOT need the addon reader, but here it is;
http://www.easydiagnostics.co.uk/shop/4 ... 3/10831437
x 8256
Re: Lexia -2- C2
I reckon it should do Alasdair...
x 1983
Re: Lexia -2- C2
I had a "Lexia map" request....I thought I should ask before they come down from Bath.
x 6963
Re: Lexia -2- C2
Shouldn't be a problem at all if your setup will talk to your X7 - the C2 ended production in 2010.
x 1983
Re: Lexia -2- C2
GiveMeABreak wrote:Shouldn't be a problem at all if your setup will talk to your X7 - the C2 ended production in 2010.
But not to a 09 Berlingo ...and yes to a 09 C5x7
x 6963
Re: Lexia -2- C2
Yes, I've read lots of issues with berlingos - wasn't the smallest of the 2008-on revised models named the nemo and developed with FIAT? - could be something to do with it...
x 1983
Re: Lexia -2- C2
ahh....that would be the reason. Was the C2 a Non-PSA car as well ?
x 6963
Re: Lexia -2- C2
The C2 was a purely PSA car AFAIK, and went fully CAN BUS from 2006 models on.
x 8256
Re: Lexia -2- C2
I have a thought at the back of my mind, may be well wrong, that the 'Lingo needed a special adaptor between the Lexia and the diagnostic socket to modify the wring a little..
The reason is that my old Lexia 2 had such and adaptor and when I looked into it that was allegedly its role in life...
x 6963
Re: Lexia -2- C2
Could be Jim, as James mentioned above, there is an adapter for the Nemo and a few of the other commercial / crossover vehicles that needs this adapter.
DHallworth
x 163
Re: Lexia -2- C2
Unread post by DHallworth »
I've used my Lexia on a Berlingo before to read/clear codes and I know Trainman has enabled cruise control on a Berlingo using his as well. From memory this one was a 2009 1.6 HDi.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
x 1056
Re: Lexia -2- C2
Unread post by wheeler »
Lexia 2's require a full CAN adaptor for full CAN vehicles to fully talk to all the ECU's. Strange that your X7 works with Lexia 2, does it read all the ECU's ?? C2's & C3's went full CAN around late 05/early06.
The other adaptor (the one with the little switch on it) is for certain ECU's on some Fiat based citroens. Lexia 2 will prompt you if this is needed.
DHallworth
x 163
Re: Lexia -2- C2
My Lexia talks to all ECU's bar two on our X7.
It says "no communication" when trying to talk to the directional headlights and says "unrecognised ECU" when talking to the telematics.
Talks fine to our 2009 C3 VTR though.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1056
Re: Lexia -2- C2
DHallworth wrote:My Lexia talks to all ECU's bar two on our X7.
David.
Are you talking about a Lexia 2 or Lexia 3 though ?
Lexia 3 shouldn't need any a additional adaptors. It's the older Lexia 2's that need extra bits to make them talk to newer models.
