AX fitting airco system
Post your Cit/Peu/Ren air conditioning queries or advice.
ekjdm14
x 267
Re: AX fitting airco system
Unread post by ekjdm14 »
Oh yeh, nothing is impossible if you want it enough & it's a good point about the AX being possibly similar to the 106 (and saxo, which appears to be the favoured donor in this case). Also the job may be helped along if the car being converted is LHD, I don't know but I think it may be as the OP is in the Netherlands... What side do they drive on~? lol
I would gather from the OP's "fleet" that they're pretty enamoured with the little Cit and more than likely au fait with the general make-up of the car so I can see it being doable if they want an "AX AC", I do think the primary stumbling block would be the heater box/space, and how efficient the system could be with whatever size evaporator is able to be fitted but it's certainly possible. Just whether it turns out being a worthwhile addition usability-wise is what I'm not 100% on, very interested nonetheless to see where this goes & I wish the OP all the best in their project :)
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
jsp
x 12
Unread post by jsp »
I have LHD car should be easy to fit.
spider
x 77
Unread post by spider »
LHD would be easier as you can then (as already put) 'target' a LHD Saxo or 106 with AC as a donor.
Seems I have to register again to look at Citroen SBox as the Peugeot login credentials are not accepted, something I would of thought they would be.
I was merely going to see if *any* (sold anywhere) AX had AC fitted...
Andy.
jsp
x 12
Thanks all Mine is LHD so will fit.
djoptix
Unread post by djoptix »
The main thing you will need is expletives. Make sure you have all the expletives you will need to hand, and get experienced in using them.
jsp
x 12
All the parts you mean?
furriegurrie
x 40
Unread post by furriegurrie »
Nope, he means all the swear words you can get your hands on :wink:
jsp
x 12
XD Will get from a saxo the parts and looming XD
jsp
x 12
I have a LHD car but, I dont the have the wiring diagram of the thermostat.
jsp
x 12
Anyone?
x 1473
Unread post by xantia_v6 »
That appears to be a controller for the compressor clutch, probably for vehicles with "manual" A/C systems. Which model and year of vehicle did it come from?
jsp
x 12
saxo 1997 sanden system. Manual system yes.
jsp
x 12
Does anyone has the diagram of the Berlingo 1.9D a/c system?
jsp
x 12
So after a few month and 50 calls around seems noone knows it?
x 6947
What exactly do you want? Mechanical diagram, electrical diagram???
