AX fitting airco system
Post your Cit/Peu/Ren air conditioning queries or advice.
jsp
x 12
Unread post by jsp »
Hi, I have a AX here and want to fit an airco system in.
What is all required?
6457 Y4 kit?
So Far I know:
Airco pump w/ bracket
condensor
pressure regulator
fan switch 3 pin
seperate box for a/c
tubing
radiator interior
and a computer that can run an a/c?
jsp
x 12
Re: AX fitting airco system
Anyone? Its getting fitted on a carb car
x 1998
Unread post by Stickyfinger »
I cannot think anyone would of done this :)
jsp
x 12
lol first time.....
x 1998
Then post images :)
jsp
x 12
AFAIK I need these parts:
6444 C0 - Valeo 817084 evap. for R134A
6451 75- temp. sensor
6461 A3 - line splitter
6460 V0 - O-RING
6460 CR - O-RING
6913 Q0 - BOLT
6453 F6 - BOLTS set
95 659 450 - connecting piece
6457 L0 - rubber isolation.
The rest are on the pictures of Cit. service:
Probably need some Saxo parts to get it working.
x 1746
Must say, as a quick response, most folk would not do this, and especially on an AX!
Conversion of non-AC cars to AC is pretty involved stuff, as you are finding out.
Much better to sell car, and acquire one with AC already there.
Repairing what is already there (if indeed necessary) far easier and cheaper than what you are considering.
If anything illustrates the old adage of it being infinitely more expensive to build a car from new parts, this is it.
Anything is possible, but I would just say - don't.
jsp
x 12
lol most of the reactions say no as always. I try to do it still. Will source a Saxo with AC refit all of that in my AX
elma
x 284
Unread post by elma »
You may run into a few unexpected challenges. For example a forum member retrofitted ac to a xantia. He showed it to me once and I hadn't realised that xantias have a smaller glovebox than the non ac ones to allow room for some of the parts.
jsp
x 12
its ok here loads of space.
x 1998
This will be fun to watch....I have Popcorn.
Go for it :)
red_dwarfers
x 58
Unread post by red_dwarfers »
It will be interesting to follow your progress, nothing wrong with a challenge :) As said, fitting AC to a non AC car has been done.
I did toy with the idea of fitting AC to my XM a few years ago but then chickened out.
Kev
'19 C4 Cactus 130 Flair
jsp
x 12
Should be straight forward need a saxo in bits......
ekjdm14
x 266
Unread post by ekjdm14 »
Will be following this with interest. Was actually considering a retro-fit on our 206 and still may do at some point in future. Did the AX ever come with air con or is it a case of adapting a car that was never built with it? If that's the case there may be issues with the heater box/fitting the evaporator but will be interested to see how it goes all the same.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
spider
x 77
Unread post by spider »
ekjdm14 wrote:Will be following this with interest. Was actually considering a retro-fit on our 206 and still may do at some point in future. Did the AX ever come with air con or is it a case of adapting a car that was never built with it? If that's the case there may be issues with the heater box/fitting the evaporator but will be interested to see how it goes all the same.
I've not looked at this (service box etc) however it may be like the (first shape) 106 is, AC is generally only available on LHD models partly due to space concerns. I am aware some later RHD 106's (quicksilver models mainly?) had AC
I don't think any UK spec AX would have offered AC as an option, however other RHD markets ('down under' etc) may of done in some cases if it was sold there.
I'm just basing these thoughts on the AX being like an 'early' 106 really...
I guess most things will um 'fit' if you're willing to make them..
Andy.
