C5 estate brake discs.
billyg55
Hi everyone. I posted a while ago regarding my radio/sat nav issues. I have resolved that by having an after market radio fitted. Thanks for all the advice given. Niw i wish to replace all four discs and pads. I can get them off the internet, but i am being asked to check the disc size. They could be either 283mm or 288mm size. I cannot see anything in the disc. Could someone please tell me were i can find the info i need ? Also is it a straight forward job or do i need special tools ? It us a c5 estate. 07 plate 2.6 hdi. Thanjs in advance. Billy
chinkostu
- x 30
Re: C5 estate brake discs.
If you post the reg or VIN we can check servicebox
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
chinkostu
- x 30
That comes back as a picasso??
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
chinkostu
- x 30
No worries man! They're 283mm
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 1496
Welllll.....billyg55 wrote: Also is it a straight forward job or do i need special tools ?
Fronts not too bad - you need a T55 to get the caliper bolts out, and one of the calipers may be LH re-wind (it was on MK1, not 100% sure on MK2), so a wind back tool will be a help.
Rears. Ha ha!!! You need to remove the caliper bolts which is where the fun starts, as they are loctited in to the calipers, and can be nigh on impossible to remove - one member had to get a local garage to cut them off.
- x 3296
I looked at the price Citroen charge for doing the brakes of a C5 Mk1. £200 for the front, £220 for the rear (which should tell you something!).
dnsey
- x 19
I don't know why the fronts should be so much. Yes, the Torx screws can be a bit of a pain, but they can be drilled out if necessary (and aren't really essential anyway). Easy otherwise.
Yes, the rears are another matter, but the calipers probably need seeing to anyway.
I understand that most dealers just cut the calipers off, so they'd no doubt charge the above price plus new calipers.
chinkostu
- x 30
Its worth adding you don't need the t20/25 on the discs, but you do need the t55 on the caliper!! If you use plenty of plusgas, a decent socket and a long enough bar they come loose easily. I had my car up high enough to use a breaker bar on them.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
billyg55
Thanks for the info. The rear calipers are goosed. Osr not working. Nsr working a little. I might look at replacements for the rear !! One more question if i may, is the handbrake connected to the front wheels ? Although there is plenty of meat on the front pads the handbrake is almost useless. Thanks again.
- x 1941
The Mk 1 and facelift (sometimes called Mk2) C5 has the handbrake on the front wheels. The X7 (sometimes called Mk2, sometimes called Mk3) introduced in 2008 restored the handbrake to the rear.
lexi
- x 133
The calipers on ebay are good. They are bought outright and they give you a freepost bag for £15 refund if you send old ones back. Two companies do them.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
chinkostu
- x 30
Chances are the mechanisms siezed, the cable operates an arm on the caliper that moves the pads. A spring returns the arms when the handbrake is off, they usually stick on. Best bet is to stick the handbrake on and see if the cables actually move the arms, as it could just need tightening.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
