x 8411
Re: I am an Activa owner...a V6 and I am an addict
Excellent!
It works out well as I have a karate grading to attend on the Saturday. I'm not grading myself this time but I'm still going to give support to those who are and to watch a 3rd kyu grading so I know that the expect in November...
That blackcurrant jam is gorgeous Alasdair, lid was on well though - needed a pair of oil filter tongs to release it :lol:
x 1994
Unread post by Stickyfinger »
More lurking
and a photo bomb
chinkostu
x 30
Unread post by chinkostu »
Some very sexy cars there!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 8411
Love the 205GTi.... Nearly as nice as the Activa next to it ;)
Weather looked a bit poo Alasdair :(
x 1994
The 205 was very nice, the owner seemed to get a little bit upset when the R5 won the best classic however. Mirrors were a little OT maybe.
Weather was overcast but warm and dry......unlike the last week here...but hey, its Festival week :)
x 8411
Stickyfinger wrote:but hey, its Festival week :)
Wet for the whole weekend then....
It's the law!
x 1994
Still raining as I type....23 hours now,
Collecting all my pallets and nails, anyone got plans for an Ark ?
chinkostu
x 30
It's monsoon season up here!
The R5 is rarer without a doubt though, the 205 is still a beautiful thing though
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 8411
At least it's not cold...
x 3296
Looking at the weather, I think the sea is attempting to retake the land by air drop!
x 1994
New Leather Care liquid applied.....not bad for 21 year old bum pads :)
x 1994
OK....and the next one.
I now have an intermittent fuel gauge.
Started the car, showed empty, light on....ummm
Turned off and re-started it, showed 1/4 full.....about correct.
Off to the garage to put £40 in, showed 3/4 full....good.
Off to the curry house, on return, light on showed empty,
turned off/on and it showed just off empty, no light.
Turned off and on, showed empty light on.
Stayed empty with light on all the way back.
Tank or gauge ?
x 695
Unread post by Mandrake »
If the problem is coming and going the easiest way to narrow it down to sender or gauge will be to measure the resistance of the sender at the top of the fuel pump assembly both when the fault is present and not present.
You can get access to it under the rear right hand seat by lifting the carpet then pulling out the big plastic bung. The outer two pins on the 4 pin plug with the thinner wires are the sender, so unplug the plug and measure the resistance:
The sender is just a variable potentiometer and it looks like it can be removed from the fuel pump assembly and replaced separately as it is just held in with small clips and has two soldered wires:
I have two spare complete fuel pump assemblies for the Series 2 Xantia V6 one of which is in the photo above. The resistance values are 350 ohms (or greater) when the tank is empty dropping to about 50 ohms for a full tank.
Interestingly when measuring the two units I have it seems one has a dodgy potentiometer - rocking the float arm slightly to the sides causes the reading to go intermittently open circuit - which would cause the fuel gauge to read empty as higher resistance is less fuel. This could very well be the problem you are having.
On the second unit I have the reading does not go open circuit when I rock the float arm to the sides so the first one either has lost the tension on the spring contacts or has a lot of play in the pivot for the arm. (or both!)
Should be easy enough to confirm from the resistance reading if it is the sender or not - given what I just saw with a dodgy potentiometer on one pump assembly my thought is faulty sender is more likely than faulty gauge for an intermittent empty reading!
x 1994
Top help......that does seem a very logical reason for the fault pattern I have seen.
Again I am indebted to you, thank you.
x 8411
Alasdair, I have a spare one here somewhere. I could drop it down to you on Saturday...
let me know...
