How to ID a Xantia VSX if you cannot see a badge ?
x 1999
Re: How to ID a Xantia VSX if you cannot see a badge ?
Unread post by Stickyfinger »
It is an LX sadly.....on an L plate, green carpets as well .....I will not take the car as it is not "special" :(
x 8422
That's a shame Alastair :(
chinkostu
x 30
Unread post by chinkostu »
Stickyfinger wrote:It is an LX sadly.....on an L plate, green carpets as well .....I will not take the car as it is not "special" :(
save it anyway? :wink:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1999
No space for a low value/interest car....
The owner is wanting it saved however.....AND ......The rear door shut areas are VERY GOOD....BUT it has lacquer flake on the boot
chinkostu
x 30
Stickyfinger wrote:No space for a low value/interest car....
is it local to you then i'm guessing?
Theres one up near me that hadn't moved for years, then all of a sudden today it's swapped over to outside a house! :shock:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 8422
Maybe advertise it on here and see if anyone wants it Alastair. How much is he asking for it?
x 1999
About £80-150 I think
In Wimborne Dorset
x 8422
What is likely to be wrong with it and how long has it been derelict?
chinkostu
x 30
it's not a sinker but it is a VSX. for that price it need saving if not at least for parts
from servicebox
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 21
STEERING POWER STEERING
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 22
TRACTION CONTROL WITHOUT ANTISLIPPING
HYDRAULIC STOP WITH HYDRAULIC STOP
HYDRAULIC PUMP PRESS PUMP 6+2 + NON-SINKING
REAR SUSPENSION SPHERE IMPROVED RR SUSP SPHERE
ACTIVE ANTI-ROLL W/O ACTIVE ANTI-ROLL
FRONT SUSPENSION SPHERE DESMOPAN WITH TALC
MAIN ACCUMULATOR SPHERE TALC DESMOPAN ACCUMULATOR SPHERE
STEERING TRAVEL STEERING MECHANISM TRAVEL 161
ACTIVE SUSPENSION HYDRACTIVE SUSPENSION
MOT history of this vehicle
Test date 18 September 2015 Test Result Fail Odometer reading 112,764 miles MOT test number 2247 2472 9946 Reason(s) for failure
nearside Headlamp not working on dipped beam (1.7.5a)
centre front lower Fluid suspension pipe leaking (2.4.D.2)
nearside rear Fluid suspension accumulator leaking (2.4.D.2)
Advisory notice item(s)
nearside front Brake hose slightly deteriorated (3.6.B.4d)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1999
is that not a LX badge on the back ?
x 8422
If it is a VSX it is definitely worth saving...
chinkostu
x 30
Stickyfinger wrote:is that not a LX badge on the back ?
Definately has the VSX tartan interior, and the reg brings it up as above in servicebox when you look the vin up
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
elma
x 284
Unread post by elma »
Badge on back means nothing, bootlid change.
That's a vsx it's the right interior and if the carpets are green well almost noone changes them and they were vsx.
x 1999
cheers chaps
