hi
as the topic suggests im after the above for my car, does anyone have any ideas?
regards
digital tyre pressure gauge
kid
yep tried there!
just to clarify im after one which can be checked and air added if required, seems the ones on ebay are just checks.
ill try my local as*a supermarket for a manaul pump version as there normally fairy cheap.
not to convinced by the petrol station ones as they may bleep but cant check accuarcy of machine + tyres are not fully cold.
cheers anyway
cheers anyway
beezer
Hmmm...didn't think I would be plugging this store:
http://www.halfords.com/opd_product_det ... e=0&cat=65
or:
http://www.shop.edirectory.co.uk/autosa ... did=815208
or:
kid
thanks, but a bit out of my league what i was after was a footpump(could not think of the name!)
i think this robust cutting edge design will do the job, i dont have a flat tyre (yet) but just want something for regular safety checks at home.
http://www.argos.co.uk/webapp/wcs/store ... kfrom=name
jeremy
- x 3
Footpumps - excellent devices but the problem with all these things is how accurate is the gauge? Having said that if you measure your pressures at home and then drive 5 miles you will probably find they are 3 or so psi higher! You will also find that no 2 gauges give the same reading and even almost new ones will vary by 3 psi or so.
A pump is a bit clumsy for checking pressures as opposed to inflation. One of these is better for checking:
http://www.machinemart.co.uk/search.asp?q=tyre+pressure
Or for luxury and convenience - the second of these:
http://www.machinemart.co.uk/search.asp ... t&x=19&y=9
jeremy
jeremy
NiSk
beezer
kid
np
beezer
np
beezer
np
NiSk
