The day after I finally got hard-to-find front hub carrier fitted & an MoT - I broke the throttle pedal; that was back in January.
Having obtained the equally hard-to-find pedal box the same garage said they wouldn't be able to do the job after all.
Can't find anywhere else (in Torbay) so, with time running out before Citromobile, just how do I do the job? While it appears to be, largely, a nut'n'bolt job, access is an issue, both inside & under the bonnet.
I understand that it's not an uncommon failing - so someone must've already done the job.
C15 pedal box
van ordinaire
- (Donor 2017)
- x 402
C15 pedal box
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- x 1484
Re: C15 pedal box
My service box doesn't give a procedure, but the book time is only 1.5 hours, so it can't be that hard!!
van ordinaire
- (Donor 2017)
- x 402
Re: C15 pedal box
Update: it involves, removing the parcel shelves (& possibly the console) s& disconnecting the steering column - plus the obvious throttle, clutch & brake.
Found some one prepared to take it on & it did take them 1 1/2 hours (I reckon it would've taken me a day) BUT hadn't noticed the clutch pedal had slipped along the shaft when off the vehicle - so it all had to come off again. That proved too much for the plastic fitting that attaches the throttle cable to the pedal, by which time it was too late (on a Saturday afternoon) to get a new cable - & I was going away the following w/e. It was cobbled up to allow me to get it home & deal was they would get another cable & fit it when I got back. Only trouble is all their usual suppliers said it was Citroen only part, so they didn't get one. I tried local GSF who just said they didn't have one, but my local factors came up with a universal cable kit for that engine although agreed it would be better to try & get the right one. Main dealer in Torquay said they could get one in 24 hours - at a scary price, payable in advance! Bit the bullet, did the business over the 'phone & they were actually a little better than their word. Collected cable , took it home, threw it in C15 & nursed it back to the place that did the job. About another 1 1/2 hours to fit that (even the OE one isn't model specific, so requires some fitting of ferrules, etc - even have to insert the inner in the outer!). Drove it home, worked fine, drove down up to Dover - Citromobile bound - no problems, in fact seemed better than ever. Came back, via Berlin & Essen, all good. Now performs better than it did when I got it AND, despite some very hard driving, even seems fuel consumption is somewhat improved - not that checks have been very scientific!
Cost more than I'd hoped (& the incidentals - like having to use the Cadillac for a couple of European trips - probably equalled that) but it's all done now, I'm really pleased with the outcome - & it's one job I'm glad I didn't tackle myself - except for the sense of achievement that usually gives.
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
spider
- x 77
Re: C15 pedal box
Although probably no help ( ! ) the actual components should be the same as the Visa and potentially the same as early (as in D plate or older) 205's
Andy.
van ordinaire
- (Donor 2017)
- x 402
Re: C15 pedal box
If you mean the pedal box, yes the Pug one might've been easier to find BUT what a performance if you found out it didn't.
As for the cable, the OE one seems to fit all applications of that engine, the factors' kit supposedly fits all PSA products using it, even x-refs. with O.E. C15 one (which doesn't actually exist) although it's not listed as an application. However I'm very chary of anything described as or purporting to be "universal" as I've learnt generally means fits nothing.
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
