They are on the Steering Wheel Boss on this car according to the Docs Paul.Paul-R wrote:Are they on the steering wheel boss or on a separate stalk on the right?john 1952 wrote:... remote controls on steering wheel...
immobilizer fault
- x 6950
Re: immobilizer fault
- x 6950
Regarding the Car networks, the restyled XSARA has three:
So it is feasible that any change (accidental or otherwise) to the wiring whilst changing the audio system over could have an impact on the anti theft system. It is also odd that the issues happened straight after changing the unit over - so not beyond the realms of possibility I would say.
I would retrace your steps, put the old radio back in and carefully go through with the Lexia first, to check the configuration is correct and see if that helps any.
- Multiplexed Networks Comfort VAN
- Multiplexed Networks VAN CAR
- Multiplexed Networks CAN
john 1952
hi mark, i didn't enable the cd changer, i don't know about the multifuntion screen,i didnt notice it, but i would not have thought about that !! i have uninstalled cd tonight, and reinstalled cassette player, but still have the same problems, i noticed the o/s/rear door wont open from inside, or outside tonight, but i don't think that could be the cause ? i was going through diagnosis again and tried"BSI +engine ECU initiation!", i put the code in when asked, it said, BSI locked, try again in 15 minutes, i did so, and got the same result ! i also tried to put code in" engine ECU initialization," got message no response from engine ECU, the player you show is the one i coded, and the remote controls did work with it,(they are on steering wheel)do you know what is the worst scenario to correct this please, many thanks, regards, john.
- x 6950
Ok, so now I'm concerned, as that option I suspect is for the pairing of the BSI and Engine ECU - and you really shouldn't have touched that at all! Hopefully, it will have blocked you from changing anything as you can only code these once and that's it. Don't change anything you're not sure of as it can have disastrous consequences.
The only thing you need do is complete a Global Test first, clear any faults, then find your way to the relevant menu to check the parameters of the Audio System and the multifunction screen. So you didn't code the CD-Changer, that's good. Just check what you have in the multi function screen parameters.
If you have everything back to normal, you really should do a BSI reset next, procedure as follows: Follow it exactly without skipping.
- Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
- Ensure all doors are closed and remove key from the ignition.
- Wait for 3 minutes, disconnect the vehicle battery and wait at least a minute.
- Reconnect the vehicle battery, wait a further minute (do not open doors).
- Switch on the side lights through the driver's window.
- Switch on the ignition and check system's functionality.
- Hold lock button on key down for 10 seconds.
- Remove key open & close door test central locking system.
- Start the engine and complete the system's check.
- Failure to follow this procedure could result in incorrect operation of many BSI related items.
john 1952
hi Mark, done another global test, but because faults are permanent, it wont clear them ! BSI faults are the same, but when i try to clear them i get, communication fault with alarm ECU, and communication fault between the built-in systems interface (BSI) and the ECUs on the bodywork van ! also, on injection, i am getting permanent fault, inlet air temp. signal can value not plausible, but i dont think that would stop it starting ! i also tried to reset alarm, but got message, no dialogue with ecu. i tried to reset the bsi as your instructions, but still have non start ! with car unlocked, alarm warning in hazard switch is off, when locked it flashes aprox. every second, when i try to start it, it flashes continuous !what are your thoughts on my next step,? what if i obtained a bsi and ecu from a scrap car, that was a known runner when scraped ? do you think that would work, or would i still have problems with the alarm, ? many thanks for your help and patience ! regards, john.
