Drivers mirror
superloopy
x 19
Drivers mirror
Unread post by superloopy »
.... dropped off. So what's the best stuff to fix this
... to this
Anyone needed to stick it back in place?
Sent from my LG-D855 using Tapatalk
Mike
x 8343
Re: Drivers mirror
Have a chat with your friendly, local windscreen man Mike.. They'll know the best stuff to use..
Once upon a time you could get the special glue needed from factors but I can't recall seeing it recently... Even if it is still available I'll expect the pukka stuff used by pro windscreen fitters will be many times more effective and better.
The Ace
Re: Drivers mirror
Unread post by The Ace »
Windscreen glue should be used, but (a) it's expensive -especially for a one-time-only job- and (b) needs extra care when applying, so an experienced windscreen shop should be a better option
x 6955
Re: Drivers mirror
If you cant get it done as suggested above - Halfrauds do a glue:
http://www.halfords.com/motoring/paints ... hesive-kit
x 1998
Re: Drivers mirror
Unread post by Stickyfinger »
I used that Loctiite glue pad/adhesive when I raised the mirror position in my Activa, it is still there
x 8343
Re: Drivers mirror
Stickyfinger wrote:it is still there
And that's a good, stern test with all the G-forces you pull in yours Alasdair!
Must be good stuff :wink:
superloopy
x 19
Re: Drivers mirror
Tube purchased ... cheers!
Mike
x 6955
Re: Drivers mirror
xantiamanic wrote:Tube purchased ... cheers!k
Just one thing - as you don't get a lot of glue - make sure you really clean the interior glass and the back of the mirror metal base first to get any grease off.
x 1998
Re: Drivers mirror
Agree....wet/dry the metal and Isoprop Alcohol the screen...mine came with a wipe which I saved for the screen.
Richard_C
(Donor 2026)
x 224
Re: Drivers mirror
Unread post by Richard_C »
Agree with the cleaning, I read a real proper academic study somewhere that concluded that most adhesive failures are the result of poor cleaning, good glue is pointless if the surfaces aren't prepared.
Lots of adhesives appear to stick very quickly but full strength chemical bonding takes longer. Ideally do the job when you won't be driving around for a few hours and adding load to the mirror as you leap from pothole to pothole. I remember doing one ages ago on a car, used the proper stuff and cleaned with alcohol, left it overnight and I was surprised to find that it stayed stuck "forever".
Richard_C
x 1998
Re: Drivers mirror
I used a large "super" magnet on the outside of the glass to apply a pulling force to the metal plate and left that on overnight
