LHD mirror vs RHD mirror
sonoramicommando
- x 5
Are the mirrors the same for LHD cars and RHD?
My car (RHD GSA Pallas sedan) didn't come with the passenger side mirror - but breaks came with mirrors on both sides looking at brochures etc?
The driver's side has remote control (manual) - is the passenger's side same as well?
Sent from my iPhone using Tapatalk
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
- x 1438
Re: LHD mirror vs RHD mirror
Don't know about the GSA, but passengers and drivers mirrors are sometimes different. They are sometimes mounted slightly fore and aft of each other to avoid the post between the window glass and quarter light getting into the field of view, they often have different curvature of the glass due to the different distance from the driver's eye.
Check at least the first point before drilling a hole in your door.
Stonehopper
- x 118
Done a bit of this. My LHD GS Pallas had drivers door mirror only, and the number of marks down the side of the passenger door side bore witness to the need for a passenger door mirror - contact with gate posts and such in the past. I obtained a door mirror to match the drivers, but later found that the passenger side really ought to have a longer arm - not by much, but enough to keep it away from the glass sufficiently to get just the right amount for the mirror to be in clear view of the drivers eye line without the A pillar intruding (which it does as can be seen in this shot).
I was also 'reliably' informed that behind the outer door skin was a welded on nut ready to take a mirror should one be desired. All that would be required was to use the drivers door as a datum point to drill a pilot hole and establish the correct location of the nut. Oh dear me - no there wasn't. No internal nut at all. For a while this left me with a precariously wobbly mirror screwed into the door skin until I was able to concoct a custom made bracket within that would securely hold the mirror.
Whether RHD or UK market models and GSA's are different - I don't know, I suspect they may be, but best get the door trim off first and take a good look inside to discover what lay beneath that door skin. It's a sod of a place to get a loose fitting nut on as there is a support channel that impedes access.
PS - And as Xantia states - you will need a convex glass for the mirror.
Derek
sandybx
- x 3
GSA door mirrors should be matt black if I am not mistaken
1992 Citroen BX TX i 1.6 auto with air con in White with 47,000 miles.
1988 SAAB classic 900 i with 3 spoke Ronals in rose quartz with 69,000 miles.
- x 5661
That's a GS though.
Mine were definitely s/s
sandybx
- x 3
I was going on pics of Andys GSA and other photos, Plus the original thread starter and the pictures of his own metallic coloured GSA with black door mirrors.
- x 5661
You are correct - I was just going on the pic of the GS above.
sonoramicommando
- x 5
so... you actually got the correct LHD passenger side mirror (longer arm) then?Stonehopper wrote:Done a bit of this. My LHD GS Pallas had drivers door mirror only, and the number of marks down the side of the passenger door side bore witness to the need for a passenger door mirror - contact with gate posts and such in the past. I obtained a door mirror to match the drivers, but later found that the passenger side really ought to have a longer arm - not by much, but enough to keep it away from the glass sufficiently to get just the right amount for the mirror to be in clear view of the drivers eye line without the A pillar intruding (which it does as can be seen in this shot).
I'm guessing GS mirrors don't have remote control (obviously).
My best bet would be getting a whole door from RHD break. It has some rust at the sill anyway :p
Can anyone confirm if GSA break came with passenger side mirror stock standard and if it has remote control?
PS I was reading the Citroen GSA technical description literature and it seems to imply one is required to have both mirrors installed by (French?) law when GSA hatchback cargo space is fully loaded (i.e. rear seats folded and packed to the roof). That would explain break & van came with both mirrors standard (according to brochures)
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
Stonehopper
- x 118
Longer arm? No. Can't find one.
Both mirrors are same length arm. The problem is seen here:
Drivers door (LHD) flat glass:
Passenger door convex glass:
A longer arm would allow the mirror to be in full view without the A pillar intruding. As it is, the mirror just clears the glass.
Looking at Citroenet, the first page for GS/GSA shows Berlines with one mirror, and breaks with two.
http://www.citroenet.org.uk/passenger-c ... index.html
Derek
- x 1438
I was at the local classic car show today, and managed to see a couple of GSAs with twin mirrors:
This one has the rectangular mounts and the mirror bodies seem to be symmetrical, so a LHD drivers mirror should fit as a RHD passenger mirror, but you would need to fit a flat pice of glass.
This one (a commercial version) has the round mirror mounts, and is decidedly assymetrical. Good luck if you need one of those.
sonoramicommando
- x 5
It looks like the passenger side mirror on the GS break on far right is at a rather different angle, steeper - I don't know if that would help situation or not.Stonehopper wrote:...
As for provision for passenger side mirror, I guess it is a lot crucial to get it right for GS, as the attachment surface area is a lot less to spread the load.
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
sonoramicommando
- x 5
Don't you mean I would need to replace the LHD driver side flat glass with a custom convex (or RHD passenger side - if they came convex)?xantia_v6 wrote:...This one has the rectangular mounts and the mirror bodies seem to be symmetrical, so a LHD drivers mirror should fit as a RHD passenger mirror, but you would need to fit a flat pice of glass....
That's absolutely hideous!xantia_v6 wrote:...This one (a commercial version) has the round mirror mounts, and is decidedly assymetrical. Good luck if you need one of those....
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
Stonehopper
- x 118
I wonder if that right hand mirror on the French service van didn't come from something completely different. Seem to recall Leyland Sherpas had something like that - at least, the later ones.
Derek
sandybx
- x 3
Dear Sonor,
Just been on " Franzoesische - Klassiker " de online gsa parts section, and they are showing your type of gsa door mirror in stock. 79.25 euros for the rear o/s door mirror ( with internally adjusted cable type ) and 69.00 euros for the rear right door mirror ( with the internally adjusted cable type )
You might have to check for their " suitability " for your car and model etc etc.
I hope this helps
I hope this helps
- x 1988
You could have a new angle milled off the base, that could rotate it down and should clear the pillar.
Do both to keep the angles matching
