Merged Lexia & Diagbox threads
Sloppysod
x 375
Re: Merged Lexia & Diagbox threads
Unread post by Sloppysod »
Almo2015 wrote:Hi people, does anyone know lexia configuration code please
What's this then? Never needed any special code?
#-o
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6960
It's a code that is required when undertaking some programming functions, usually when replacing certain components of programming values Stu.
Sloppysod
x 375
Thanks Marc, is there a list somewhere of these parts?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6960
No lists I'm aware of Stu, I think it used to be requested when making configuration changes to the BSI with the Lexia software App - I've never been asked for it using Diagbox on my car for anything I've needed to do. It's some form of protection for sensitive areas to prevent accidental changes I assume!
Almo2015
Unread post by Almo2015 »
#-o
It's when you change things on bsi eg turn automatic wipers on/off etc, code is 03114 if you ever need it Sean
Almo2015
What diagbox version comes after 7.65? And where can I download update file? For some reason on version 7.65 automatic car detection doesn't work? Thanks Sean
Ps everything else works great tho
Sloppysod
x 375
Cheers Sean, as Marc says, it is a Lexia thing and not Diagbox. But handy to know.
Sent from my GT-I9195 using Tapatalk
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6960
Almo2015 wrote:What diagbox version comes after 7.65? And where can I download update file? For some reason on version 7.65 automatic car detection doesn't work? Thanks Sean
Sean - This won't be anything to do with your software version - this will likely be down to another issue - 7.57 is the most stable. IF you were able to use it before and have updated it recently, to find that it is not working - you mat have upgraded it past the hardware capability. You generally need to have a 'Revision C' unit with appropriate firmware to use all but the earliest versions of Diagbox V7 (see previous posts in this thread). Trying to upgrade a Revision 'B' unit to anything later can cause problems with communications with a range of vehicles and could render your unit unusable (as Diagbox also upgrades the firmware required for the software version - unless you have disabled this), so you may not be aware. Use the PSA Version Checker linked in the previous posts to determine your revision and firmware. :-D
Almo2015
thanks for reply marc ive got the latest firmware(revision c unit) v4.3.3@actia 27.06.14 how can I go to 7.57 diabox?
x 6960
PM Sent Sean
Xantianut
x 121
Unread post by Xantianut »
Ay up!
This is annoying,
I logged my Lexia onto the system last time but when I tried to use it today, it demanded to be registered! And guess what, I've forgotten how to do it and can't find the instructions on the disc.
Any experts out there willing to help? Please PM me contact details and I'll arrange a time......
Baffled by technology, that's me!
Oh, and as for the code 03114, is this the general code for all cars or will I need an individual code from the dealers?
As you can tell, I am new to this computer diagnostic lark.
RIP
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
x 6960
That code is usually used by the Lexia specific app and generally isn't needed with Diagbox. The code is for Citroen - and no - don't be asking the dealers for any codes or you'll likely be carted off!
Back to the Lexia - is this Diagbox you are using as the front end that runs Lexia - or are you using a native Lexia programme without Diagbox. If it is Lexia stand alone - I can't help you, but if it is Diagbox, are you sure it is registration or activation it is requesting? As you can see specifics are all important here otherwise we could be talking about different things. :-D
Xantianut
x 121
Ay up!
I can get the diagbox bits to work. Am I right in thinking this is the measurement menu? It keeps asking me for a write code so is the number quoted above or is that the code that was on the key card that should have come with the car but didn't?
It's just the Lexia bits that are confusing me.......
RIP
BX19DTR (Fifi 2)
x 6960
:wink: No it's not your key card code it will be the code 03114 then. The measurement menu is usually for connecting other kit usually at the Citroen Dealer - just be careful what you change
Fake Concern
x 65
Unread post by Fake Concern »
I have been fighting with Diagbox/Lexia/Peugeot Planet all week. I can get my C4 to connect, the vin is correct & it will check every ecu. I haven't been able to find what the fault codes stored are as after it read the log, it said "fault log empty".
However the problem I want to sort out first is it won't let me change anything. On my C4 the directional headlights had been unplugged and need to be enabled to work. I found the screen to change them but got this screen
I tried the code 03114 and it said "warning incorrect code"
Today I connected to my daughter's Peugeot 207 to enable the CD changer and again found the correct place but got the exact same message as above. I tried 12345 and various other numbers, but no good. Anyone know what the "code supplied by technical assistance" should be?
