- x 8353
Re: I am an Activa owner...a V6 and I am an addict
In good company!
- x 1999
So....a new "problem"
Interior fan not working. Zero Blow
From what I can gather from other posts I need to do the "Ignition Switch" Mod...........
BenC5HDi
- Not Mike
- x 45
Ignition switch mod or check the connector on the motor unit. It had melted on my S1 Activa..
- x 8353
Look at the sticky on this subject and get a multimeter in there...
If ignition switch it can often be proved by wiggling the key around.. Sometime the blower will start and stop with the wiggling..
- x 8353
- x 1999
Have one going in shortly Jim
The "Key Wiggle" gives zero result.
Fan works in the donor car.....so I have bits available
- x 1999
Plug 1....cut into this ?
Plug 2....what is this spare plug for ?....cruse control ?
What plug is it on this ............ BB10 ?
some more pics
and the things you do to a (recovered) thick steel work top, it needed a rust converter, so a pattern it was
(will rub wax in tomorrow).
some more pics
superloopy
- x 19
Looks strange ... everything being the 'wrong' way round as though you'd reversed the pic
Mike
- x 1999
Fans working.....it was a poor connection on the brown plug.
All cleaned up and protected with wax contact preserver....
Will do the mod another time.
BenC5HDi
- Not Mike
- x 45
That's the connector I mentioned. It's been a while and I couldn't recall what colour it was.
- x 1450
That is not the Cruise Control control plug (wrong colour and shape and not enough wires).Stickyfinger wrote: Plug 2....what is this spare plug for ?....cruse control ?
Is it not the instrument light dimming rheostat connector?
If your car has wiring for cruise control, there should be three wires going to the brake light switch (at least on the car side of the connector).
- x 1999
correct, rheostat for the dash lights.......I could not work it out on the photo.....dogh !
Will look for the three when I do the ignition mod next week.
Cheers chap
Cheers chap
- x 8353
Please you found the problem Alasdair
I had a poor connection on the brown plug on the blower once and I could just smell it burning...
Keep an eye on it as if it's been hot the spade connector in question often looses temper and can make a poor connection all over again..
- x 1999
Zero signs of heat Jim............ which is one reason why I put it back together.
As the fans have been on AUTO and I have not needed Fans (so had not used the slider) I think they have not worked this year
I feel these "niggles" will happen as the car has gone from a dry life to a damp one, hence my habit of using the wax contact preservative spray in every electrical block I touch or can get at.
- x 8353
The fan will have worked Alasdair. You would have known if not as a Xantia is practically impossible without a blower running. Without it there is no airflow at all in the cabin and the windows steam up something rotten... Plus no heat just when you might need it..
