Peugeot 306 keys
mixalis kal
x 23
Re: Peugeot 306 keys
Unread post by mixalis kal »
No,no... I mean that my cars name is Peugeot 306 style ! When I google it I find some styling products for the car , xenon lights etc. I am asking if there is an other name instead of "style" for my car such as SL, XT , DT.
spider
x 77
Unread post by spider »
mixalis kal wrote:No,no... I mean that my cars name is Peugeot 306 style ! When I google it I find some styling products for the car , xenon lights etc. I am asking if there is an other name instead of "style" for my car such as SL, XT , DT.
This varies a lot depending on country.
If you want a random example (this does not apply here but I wanted to point it out)
UK models (new shape) are badged L (no badge) / LX / GLX , the *identical* car (even in RHD) sold elsewhere is badged XR/XT
MK1 (your shape / model) are badged:
XN (Base model)
XL , Base model plus central locking, sometimes not remote only manual key in door operation. Optional power steering, optional electric windows. Later have these.
XR , Midrange model. Remote cerntral Locking / Electric Front Windows / Power Steering all fitted. ABS optional.
XT , As XT plus a bit more. Rear electric windows, ABS more common. Rear headrests
Note: A 'D-Turbo' is actually an XRDT 3door. This was not sold here but it is common in LHD.
Your model: 'Style' , these are typically XN or XL based with Power Steering and Central Locking fitted.
Andy.
x 5675
Odd, my son had a D-Turbo 306. (UK). Great little car. Fairly high spec.
mixalis kal
x 23
Ohh.. You really know everything about Peugeot !! :-D
Mine has power steering , central (remote ) locking fitted , airbag ( with one red light on it ),keypad and electric front window ! That means that it is a XL?
spider
x 77
mixalis kal wrote:Ohh.. You really know everything about Peugeot !! :-D
I should of mentioned the airbag. High models had this before low ones.
Do you have a tachometer / rev counter ?
XN had time clock / speedometer
XL / XR / XT etc have tachometer / speedometer and digital clock (clock in centre console)
That will be the deciding thing I think as the other items are (in theory) optional on XN mostly.
If you have a tachometer: You have an XL
If you do not have a tachometer: You have an XN
Andy.
mixalis kal
x 23
https://imageshack.com/i/plV9Y1F2j
Also I have a digital clock at the center console !(without temperature )
spider
x 77
mixalis kal wrote:https://imageshack.com/i/plV9Y1F2j
That's the XL panel. So your model is an XL with a different badge. If you can show me the seat / door panel trim that might help but I suspect that will be different for a 'style' anyway.
Only XT (possibly some XR) and XS have the temp in the clock as well.
Andy.
spider
x 77
myglaren wrote:Odd, my son had a D-Turbo 306. (UK). Great little car. Fairly high spec.
That is correct though. :) , For France it tends to be badged 'XRDT' , same spec slightly different seats but otherwise about identical (apart from LHD/RHD)
What I am saying really is a D-Turbo badged car is equivalent to an XRDT, but UK models at least XR's are 5 door only. So if you wanted a 3door XRDT, you'd get a D-Turbo.
A/C rare on MK1 (UK models at least)
Standard drivers airbag, PAS, Electric Front Windows, Central Locking. ABS optional
Andy.
mixalis kal
x 23
http://imageshack.com/a/img923/5760/E6SIXo.jpg
I have put an other cover on seats ...but you can see it if you zoom at the door panel.
Also , I have A/C!
spider
x 77
mixalis kal wrote:http://imageshack.com/a/img923/5760/E6SIXo.jpg
Also , I have A/C!
Yes I can see.
A/C is more available in other countries (then we got it as well on more models about 1997)
You have 'XR' door panels although the seat trim does not match the UK XR trim design. I would suspect that you have what was an XL in effect with A/C. :)
Andy.
mixalis kal
x 23
So I have the XL edition !! These have to be differences between uk and Greek models... Now I am trying to find a remote key (1 button) and the central unit but it is really difficult to find one . I also tryied to find it with the product number 6552RT but nothing in Greece and at eBay ...
spider
x 77
I'm pretty sure that the 106 / 405 ones will fit these as you have the early infra-red single button 'pre-coded' unit.
Are there no 106 / 405's you can get one from ?
Very late 205's have this as well, about 1995 to 1997
Andy.
mixalis kal
x 23
Unfortunately not... I have already search for it but nothing ...neither for 205
spider
x 77
mixalis kal wrote:Unfortunately not... I have already search for it but nothing ...neither for 205
Can you not find one on another Ebay (Ebay France/Germany etc) and see if they will ship to you ? I know its a bit of a risk though...
Andy.
mixalis kal
x 23
Unfortunately there isn't another way .. I have to try it IF I find one !!
