Peugeot 306 keys
mixalis kal
- x 23
Re: Peugeot 306 keys
Thank you very much! I understood ! Because I don't know how to recognize the port I I will take a picture on Wednesday to be sure !!
spider
- x 77
Fusebox under steering wheel:mixalis kal wrote:Thank you very much! I understood ! Because I don't know how to recognize the port I I will take a picture on Wednesday to be sure !!
Andy.
mixalis kal
- x 23
I found on the Internet a workshop manual but I have to pay ... Is it possible to find one for free ?
spider
- x 77
Erm, not legally no.mixalis kal wrote:I found on the Internet a workshop manual but I have to pay ... Is it possible to find one for free ?
What did you actually want though ?
If you only want bits of information I can probably help as I have Servicebox and Sedre
Andy.
mixalis kal
- x 23
Nothing specially .. My engineering told me about that and that it would be good to have it as my car is old enough ...!!! What is sedre? It doesn't really matters if it is legal ..
- x 5678
Unfortunately it does at least as far as the forum is concerned.mixalis kal wrote: It doesn't really matters if it is legal ..
We could be sued for distributing or aiding in the distribution of copyrighted materials.
As individuals we are free to act as we see fit (and bear the consequences thereof) but the forum can't be involved.
mixalis kal
- x 23
I am sorry .. I didn't know that this may cause problems to the forum !!
spider
- x 77
If a new one is too much then your local Ebay might have some used / second hand ones.mixalis kal wrote:I am sorry .. I didn't know that this may cause problems to the forum !!
Andy.
mixalis kal
- x 23
I will search for this !
I think that I can learn some new things about my car reading this manual !!
mixalis kal
- x 23
Searching on the Internet I read that low battery makes the keypad crazy.. is that true?
spider
- x 77
Low voltage can have a lot of strange effects with electronics, so 'yes' to answer you.mixalis kal wrote:Searching on the Internet I read that low battery makes the keypad crazy.. is that true?
High resistance (as you found in that plug in the engine bay) can also have odd effects too.
It is more a "problem" with newer "multiplexed" models but older cars will still had 'odd' effects if they have low voltage.
Andy.
mixalis kal
- x 23
What do you mean with this ?? I can't understand this !!
spider
- x 77
It just means where the electricity has problems passing. A good example would be where the pins in the plug are rusty (going green or brown!) or where the copper wire has turned green.mixalis kal wrote:High resistance (as you found in that plug in the engine bay) can also have odd effects too.
Your engine 'plug' probably had high resistance until you moved it.
This causes "high resistance" which means that you might put 12v in one end and only get 10v out the other.
There is a lot more to it , but I wanted to explain it in an easy way if you have to 'translate' any of this.
Andy.
mixalis kal
- x 23
I understood !! Do you know if there is any other brand for 306 "style" ? When I google it i see some car styling products ..
spider
- x 77
Brand of what ?mixalis kal wrote:I understood !! Do you know if there is any other brand for 306 "style" ? When I google it i see some car styling products ..
Are you looking for a battery or something else ?
Andy.
