Tartan Travel Rugs and other Nostalgic Motoring Accessories
x 1746
Re: Tartan Travel Rugs and other Nostalgic Motoring Accessories
bobins wrote:My Land Rover allegedly has a heater, although I'd regard it more as a tepid-er, to call it a heater is overselling it a bit :)
Rover and other bits of BL had a long tradition of fitting ludicrously low-temperature engine thermostats - 78C, 82C....
Many a vehicle's heating system transformed by simply swapping for an 88C or 92C 'stat.
x 8385
Wasn't it some Fords that had vacuum operated wipers as standard?
What a great idea, variable speed ones depending on throttle opening.... :roll: :lol:
No doubt when you most needed them there was no vacuum available and they were either very slow or stopped..
About as good as dynamo lights on bikes. The lights that only worked when you were pedalling... Brightness depended on speed...
I had bike dynamos when I was a kid. Tyre wear was epic and the way they slowed you down when use use was not good... Hence rarely ventured out on a dark night....
x 7163
You might expect the 2CV to have odd wipers
from wiki
On the earlier Citroën 2CV, the windscreen wipers were powered by a purely mechanical system, a cable connected to the transmission; to reduce cost, this cable also powered the speedometer. The wipers' speed was therefore variable with car speed. When the car was waiting at an intersection, the wipers were not powered, but a handle under the speedometer allowed the driver to power them by hand.
...and the SM was one of the pioneers of the rain-sensitive intermittant wipe!
x 8385
Now we know why 2CV drivers always go as fast as possible!!!
NewcastleFalcon wrote: ...and the SM was one of the pioneers of the rain-sensitive intermittant wipe!
How did that work then?
x 5669
CitroJim wrote:Wasn't it some Fords that had vacuum operated wipers as standard?
A friend had a pink Vauxhall Cresta that worked that way too.
x 8385
myglaren wrote: A friend had a pink Vauxhall Cresta that worked that way too.
That conjurers an image in my mind Steve :lol:
Actually, if it was a PA Cresta they looked absolutely sensational in pink 8-)
x 1746
As a teenager, was driven from London to Edinburgh (for the Festival) in a pink/grey two-tone PA Cresta, and that was before any motorway speed limit was introduced. IIRC, also before headrests, seatbelts and central reservation crash barriers. Doesn't bear thinking about these days.
Same owner later replaced the car with a dark green PD Cresta, 3.3L Powerglide. Amazing use of sheet metal, and room for a team of mechanics to stand in the engine bay!
x 8385
white exec wrote: and room for a team of mechanics to stand in the engine bay!
Wish that was the case with an Activa :twisted: :lol:
x 1746
...and the 2.5 XM. Unlikely that any tool/widget dropped will ever reach the ground :(
x 8385
white exec wrote:...and the 2.5 XM. Unlikely that any tool/widget dropped will ever reach the ground :(
Same with a V6 XM. I know, Ragger's XM V6 will still have one of my Torx bits in the engine bay somewhere!!!
x 3296
I can see it now. A large engine XM gets pulled over, as the police suspect something is amiss. They empty out the car, and weigh it (amongst their other checks), and find it is 75KG overweight. They suspect a large amount of contraband, and so get the XM stripped down by a specialist. The report that comes back is thus;
After taking the vehicle completely apart, we were unable to find anything of a suspicious nature. However, we did find a large number of extraneous items, mainly in the engine bay, detailed as following;
37 3/8th assorted sockets
2 3/8th socket wrenches
41 assorted Torx bits
5 assorted combi spanners
1 3 foot breaker bar
1 2.5 tonne trolley jack
1 torch, and 1 workshop light unit
12KG of various nuts, bolts, washers and similar
1 new clutch plate, suitable for the vehicle in question.
At first we were unable to explain this, until somebody pointed out the vehicle in question was a 20 year old Citroen XM V6, and then we realised that this was (upon research) the normal situation with this type of car.
x 8385
That’s brilliant James :lol: Love it!
If they ever do the same to any 1.9TD engined vehicle they'll find thousands of old glow plugs hiding behind the injection pump cradle ;)
x 7163
CitroJim wrote:Now we know why 2CV drivers always go as fast as possible!!!
Well I'm no expert but this is the explanation on wiki!
In March 1970, Citroën introduced rain-sensitive intermittent windscreen wipers on their SM model. When the intermittent function was selected, the wiper would make one swipe. If the windscreen was relatively dry, the wiper motor drew high current, which set the control circuit timer to delay the next wipe longest. If the motor drew little current, it indicated that the glass was wet, setting the timer to minimize the delay.
x 8385
Thank Stu :D Now that's really clever and a great piece of Citroen lateral thinking! I love it!
x 7163
CitroJim wrote:Thank Stu :D
That's not modern text speak is it Jim? Not sure who Stu is.
