Tartan Travel Rugs and other Nostalgic Motoring Accessories
Re: Tartan Travel Rugs and other Nostalgic Motoring Accessories
Anyone remember the demister panel?
Even the police used them!
x 1994
Unread post by Stickyfinger »
Yes...it worked very well, then it went yellow during the first summer :)
x 8412
Stickyfinger wrote:Yes...it worked very well, then it went yellow during the first summer :)
I only ever remember them being yellow!!!
x 1994
then they were 6 months old minimum :)
1st one I did was a stick on element type on my Austin Cambridge A60
BenC5HDi
Not Mike
x 45
Unread post by BenC5HDi »
I use a similar, smaller device even now on my motorbike helmet. I've had it for years, just need another motorbike to go with it..
x 8412
Does anyone remember those little windscreen demister/deicers popular in the 60s and interned for cars without heaters. In the dead of winter it would keep a little slot-like area of the windscreen clear of ice - just enough to see where you were going...
If I remember correctly, they were made of brown bakelite and stuck on the inside of the windscreen with a couple of rubber suckers...
I've had a look for images but can't find any. I bet you can Neil ;) :)
CitroJim wrote: I've had a look for images but can't find any. I bet you can Neil ;) :)
Not come across one yet....but on my travels, from the days when heaters were very much add-on accessories for the masses, this was a simple and ingenious device,
If Mr or Mrs Motorist had a smaller car, where under-dash space was at a premium, then some of the larger heater units discussed above might not have been an option. However not all hope was lost, as the "Heat-A-Car" unit was a very different design to the norm. Instead of a bulky heater radiator and motor unit hung beneath the dash, this alternative featured a 24" tube, with a clamp at one end that fitted to the car's steering column, and a bracket at the other that screwed to the facia. No motor was involved, you simply plumbed it into the car's cooling system and it enabled hot water to flow along the tube, radiating heat as it did so. Handy for drying damp gloves on too I imagine, although doing so would soon steam the windows up.....
....Smiths demister top right close?
Now this little device may be more 1950's, but it does appear to attach to the windscreen with "suckers".
x 1746
"Houdaille Hydraulic Suspension" - You've opened a pandora's box there, Neil !!!
My first car, a 1935 Rover 10, had rotary-arm shock absorbers, oil-filled. Luvax brand, they were stiffness-adjustable.
white exec wrote:"Houdaille Hydraulic Suspension" - You've opened a pandora's box there, Neil !!!
Only attention.... "Castor Oil every 4,000 Miles"
x 8412
Neil, this topic just gets more and more fascinating and enjoyable :D
x 1994
My Healey has a version of the (top right) Smiths heater....its totally crap !
x 3565
My Land Rover allegedly has a heater, although I'd regard it more as a tepid-er, to call it a heater is overselling it a bit :)
Houdaille's other products was the Electric Windscreen Wiper, at one time also an "accessory".
