C5 Mk III suspension issues
x 6955
Re: C5 Mk III suspension issues
I'll see if I can pump some screenwash out using the pond pump :rofl2: tomorrow as I can't remember whether it was a written warning Message or a bulb type message! I don't know, the things we do here ....
x 1995
Unread post by Stickyfinger »
:) hit it with a Percy
x 6955
Or an MC!
vborovic
Locked user account
x 40
Unread post by vborovic »
@ sticky - Do you have xenon or halogen headlamps?
x 1995
halogen headlamps
vborovic
Locked user account
x 40
That's why ... only the xenon's have the washing fluid sensor fitted and activated (due to the larger washing fluid container - for the headlamps washing as well)
x 1995
Well I never.....stupid, just stupid :)
x 6955
Well that's saved me from pumping out the fluid! 10/10 VAB
vborovic
Locked user account
x 40
Ask me ... I wanted to retrofit it ... :D ... it might be done, but for the level sensor to be active you need to enable the headlamp washing system ... when that's enabled, it tries to link the xenons ... which I don't have ... let alone directional and leveling ECUs ... meaning, I'd have a washing level sensors active, and about 10 permanent errors due to missing equipment ... :D ... my dad's C5 2005 has that feature without the xenons ... go figure the Citroen's logic in that...
x 1995
Both my Mk1 and Facelift had it with standard bulbs.....as did they a bonnet lift ram.....another go figure ?
Xantippa
x 29
Unread post by Xantippa »
vborovic wrote:That's why ... only the xenon's have the washing fluid sensor fitted and activated (due to the larger washing fluid container - for the headlamps washing as well)
I've got halogens and fluid sensor. I have headlamp washers as well.
And I don't like that feature very much, just another annoying beeping sound. :evil:
vborovic
Locked user account
x 40
That was standard or did you switch to halogen headlamps from the xenons (people actually do that)? All the available data I have never showed an option halogen + washers (you couldn't even order such a combination) ... then again, it's all up to the market and the car variants
Xantippa
x 29
No, I think all C5's in Finland have headlamp washers. Long winter, salty roads and so on...
vborovic
Locked user account
x 40
That means there should also be a combination in the BSI that allows for the headlamp washers option (+ washing fluid level sensor), without the xenons ... I'll have to go through the configuration options once again ... :D
Xantippa
x 29
Btw, noticed with Lexia that headlight height ecu or something like that is not present. Same thing with two X7's with hydropneumatic suspension. So retrofitting xenon-headlights would mean also adding that ecu-thing. Height sensors are already there, but without brains for xenons.
