BenC5HDi
Not Mike
x 45
Re: RE: Re: I am an Activa owner...a V6 and I am an addict
Unread post by BenC5HDi »
daviemck2006 wrote:Ive never had leather seats in a car, and dont really want.
I've had it in a few cars and I don't like it at all. Activa cloth, MK2 Impreza or Saab C900 seats are the comfiest for me.
MK2 Impreza seats are a bolt-in swap for Berlingo ones :)
Sent from my SM-N9005 using Tapatalk
daviemck2006
x 485
Unread post by daviemck2006 »
Mk2 impreza seats went into my first 107 with very little fabrication. Made a massive difference to it!
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
chinkostu
x 30
Unread post by chinkostu »
daviemck2006 wrote:Ive never had leather seats in a car, and dont really want. I wont be looking for for the activa as I like the seats in it, the pattern, the feel of the fabric and the comfort of them. The foam on mine is on the way out also, common problem then.
The leathers aren't quite as comfy as activa cloth seats, but its easier to find that sweet spot. I could never get it 100% with the cloth ones.
Tbh i'm never usually a fan of leather but they really improve the looks inside.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
BenC5HDi
Not Mike
x 45
daviemck2006 wrote:Mk2 impreza seats went into my first 107 with very little fabrication. Made a massive difference to it!
They'll be going in the Bingo too once I find a decent pair at a reasonable price!
daviemck2006
x 485
I got lucky, got a full, tidy interior for 99p on eBay! They were in Aberdeen, the guy just wanted rid. I sold them for £100 after I sold the 107 [emoji5]
Peugeot boxer 2016
In the family
x 8415
I personally find the C1/107 seats just the job but I guess for you gentlemen of somewhat larger proportions than I then they are a bit on the small side...
x 1994
Unread post by Stickyfinger »
Roughing up the light housing to accept the Hella units.
I will make a set of supports using alloy first then use steel, these will hold the adjustment screws.
I will "weld" these in using resin and add a couple of rivets when in the correct position. Once all the position is correct I will make a cover piece and paint that silver to hide the mounts and keep the OEM look through the lens.
The cut-out in the top & bottom will get a fibreglass and filler layer once I have checked the clearance. I will try and make the little bulge disappear by building up the removed plastic to the original pattern including the two triangular bracings found on the OEM units.
Skull
(Donor 2026)
x 382
Unread post by Skull »
The Badgers wont stand a chance :shock:
Gary
x 1994
With luck I will melt them before hitting them :)
x 8415
Looking good Alasdair :D
x 1994
Setting up a rough for the "decorative" plate and getting the spacings for the lamp units correct.
x 5672
The corrugations finish it nicely - will you be patenting that technique?
x 1994
Once I am sure that all fits (it looks OK atm), then the glass will go off for grinding/polishing to rid it of the flutes.
There is a "slight" risk of the glass cracking during the polishing but I have two full sets of RHD ones so not really bothered if one goes PoP.
Slightly tempted to add a third light.....
superloopy
x 19
Unread post by superloopy »
Just picked this up sticky and was about to add 'would look so much better with a third light' when i reached the end of the thread and read you've beaten me to it ... looks a little sparce otherwise. Or use bigger beams and stick with two. Cant get a set of morettes then?
Sent from my LG-D855 using Tapatalk
Mike
x 3296
If you had a third light, how much would the be involved to allow it to turn in sync with the steering, as on the DS?
