1994 Xantia 1.9 TD
It runs and drives OK but when I rev the engine beyond 2500 - 3000
it makes a funny noise like a resonant flapping/drumming from the
engine. It sounds like maybe the intercooler plastic pipes are
vibrating on boost or something. On the odd occasion I managed to get
rid of the noise, but I don't know what was causing it. I thought I'd fixed by using cable ties on everything, but the noise returned.
I've checked the whole induction system, (which has a lot of possible
rattles) and it looks OK. The rest of the engine is spot on and it's not the cam or alternator belt. Maybe it's something to do with the hydraulics or cooling system, or perhaps an engine mounting. It's not
a major problem, but I don't like it and it shouldn't do it.
Suggestions ???
Xantia - funny noise
nick
When the accumulator sphere was going flat on my Xantia I used to get a sort of rattling noise when the engine was revved. Just the hydraulic system repressurising, which it has to do much more often if the accumulator's flat.
The noise you get on Xantias seems quite different to the straightforward 'click' BX's make when they've got this problem. Its a difficult noise to describe, but I think the best description I've heard was 'like someone twanging a wooden ruler on a school desk'!
Nick
Nick
KAD
I think I've found the problem now.
The oil filler has a breather pipe connected to the inlet
manifold rubber ducting and at the end there is a round valve.
I took this off and I can blow through it both ways, that has
to be wrong, I'm sure it should be a one way valve. As it is,
turbo boost pressure will go down the filler neck and into the
sump, which I'm sure would cause the problem.
A new valve is on order. I will confirm if this fixed the
problem.
problem.
Dave Burns
KAD
stevenlizuk
KAD
nick
KAD
nick
Engine noises can sometimes be located by using a piece of flexible pipe as a sort of stethoscope, but as it only does it under load you may have to find a very small person who's prepared to travel under the bonnet for a while <img src=icon_smile_wink.gif border=0 align=middle>, or use a rolling road.
Alternatively, all I can suggest is where possible remove ancilliary things like intercooler pipework, alternator drivebelt etc, one by one, and try driving for a short distance with each removed to see if it cures it.
Thats pretty much what I had to do when my Xantia started making an annoying whistling noise on acceleration. Turned out to be the inlet manifold gasket, but it took me weeks to find it.
Nick
Nick
KAD
I have reduced this noise by replacing the old soft and squidgy
lower rear engine mount, the one which is near the drive shaft. It was not a fun job to do, but it only cost £13. The old item allowed the engine to twist back too far under load
and I guess things were coming into contact and making noise because of that. It has also taken away a slight 'wobble' which I had noticed under light load. It has made the car feel altogether more solid.
That lower mount takes a lot of punishment and the old one had done so for 170,000 miles....not too bad I suppose.
