Many years ago when I did diesel conversions there were no stop solenoids, you had to connect the redundant choke cable to the stop lever, this transmitted a lot of noise up the the dashboard so I didn't usually bother,. the standard way of stopping was to put it into gear and stall it.
Quick diesel shutoff question
- x 1240
rory_perrett
Re: Quick diesel shutoff question
Had this problem on a Land Rover 200tdi with a Bosch pump. When I partially stripped the pump I found some metal debris that was stopping the cut off valve from seating properly. I fear the metal debris is an indication of problems elsewhere in the fuel system.
superloopy
- x 19
Anyone able to have a look on service.citroen for me and get the part number of a stop solenoid valve. My pc is playing up and i've lost my login details for the site.
Sent from my LG-D855 using Tapatalk
Mike
rory_perrett
Part number 1680 85 at £113.06 OUCH!!!
Or if its a Bosch pump 1680 95 at a more reasonable £83.80 (inc VAT) One for the Land Rover is about £8
- x 8422
Any decent diesel servicing outfits should eb able to supply Mike, also, the stop solenoid is the same right across the range of Bosch VP pumps..
Here's one:
eBay Link
EDIT: That's a 24v one but you get the idea...
Here's one:
eBay Link
BenC5HDi
- Not Mike
- x 45
Re: RE: Re: Quick diesel shutoff question
Find a local diesel specialist and ask them. That's what I did with my ZX 10 years ago. It cost me about £20 including fitting! I recall the same part from the dealer was more than the car was worth !xantiamanic wrote:Anyone able to have a look on service.citroen for me and get the part number of a stop solenoid valve. My pc is playing up and i've lost my login details for the site.
Sent from my SM-N9005 using Tapatalk
- x 1496
Amusing prices from Citroen....
0000168093 ELECTRO VALVE 64.75 GBP 77.70 GBP 77.70 GBP (Since RP 7764)
0000168095 ELECTRO VALVE 69.83 GBP 83.80 GBP 83.80 GBP (Up to rp 7764)
superloopy
- x 19
Thanks people! I've sourced a Bosch replacement (1680.95) at £36. Not too bad although true to citroen form, three times on Saturday and she's not ran on once since! Never mind ... it'll go in the spares box for the time being. Next episode and it will be in there (assuming i'm capable).
Mike
