x 8411
Re: I am an Activa owner...a V6 and I am an addict
I suppose you’ll be wanting your money back now Alasdair :lol:
Seriously, good to know what it is that wrecks them...
x 1994
Unread post by Stickyfinger »
Oh crap.......guess what I forgot to give you !!!!!!!!!!!!!!
A bit of a shame that the seat foam was fubar on this one as well ....thats the way the cookie crumbles at times :(
Jim, do you know if the ebay type seat heater elements fit to the standard wire/switch set up ?
x 8411
Off-Hand Alasdair, no I don't. They're worth a try though and see if they work... The regulator is electronic so it should be able ton accommodate a range of pads I'd have thought...
I have a feeling someone tried them in an XM and found them OK...
Are they expensive?
x 1994
various from £20 - £60
x 8411
Give a £20 one a go and report back Alasdair... It'll be valuable knowledge, as is how to get the seats apart...
x 1994
The seat covers are easy Jim, take off the belt tensioner and then you just need some new HOG rings when reattaching the cover.
x 8411
Excellent!
x 1994
more seating images.
Note the heat pads are sewn onto the leather....ummmmm
Note the "problem" switch box
x 8411
Ahh! there's the problem.. It's German!!!! Wet German at that....
daviemck2006
x 485
Unread post by daviemck2006 »
German build quality strikes again [emoji15] [emoji12] [emoji23]
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 1994
Well I got a foam section from a rear seat squab, I shaped it and applied with 3m spray, taped for 12 hours to fully set.
Old section as a pattern
taped and left to set up ...messy job :)
x 8411
Looking good Alasdair 8-)
x 1994
The Activa is booked in for a pair of HeliCoils to be fitted to the head to cure a small oil leak that is persistent from the top cam cover.
One thread was filled with "metal filler" and another was just butter so must of been stretched. I will take the responsibility for the second one and blame the French for the LeBodge on the first. The strange thing is the leak is on the other side from the damaged ones ? I will get it all sorted at the same time.
I have decided to go for a hand built SS exhaust (Infinity, Bristol) , a CAT back system with the middle box removed and built with 2 1/5 inch pipe. I will get them to make up a pipe and flanges to the system so if I decide later that I do not like the noise or if I discover after a few miles that any drone is spoiling the enjoyment then I will be able to insert a middle box.
The back box will be built so as to look "Standard issue" with twin straight tail pipes.
MOT due at the end of next month.
Today's job, lube my struts as I have some creaking that is driving me nuts when I pull up slow at lights/corners etc.....I hope that is the cause
x 3296
:-D You sure that the creaking isn't your knees or hips, Alasdair? :-D
x 1994
Could be :)
Well after Wind, Rain, Snow, Hailstones, a plague of Locusts and the Four F'ing Horsemen of the Apocalypse I finally got the Water and Oil changed as well as installing new bulbs into the heater panel.
Dug some of the vegetable garden over as well......boy oh boy do chickens risk their necks for a worm :)
