daviemck2006
x 485
Re: I am an Activa owner...a V6 and I am an addict
Unread post by daviemck2006 »
Upside down on the wrong wrist. That will sort it!
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 8406
I guess this one doesn't roll around your wrist?
BenC5HDi
Not Mike
x 45
Unread post by BenC5HDi »
No, but it shuffles from side to side if you stop moving.
x 8406
BenC5HDi wrote:No, but it shuffles from side to side if you stop moving.
:rofl2:
x 1996
Unread post by Stickyfinger »
The car is running franticly well atm with it rising almost instantly on the new pump/regulator, the engine is so quiet and the power steering has improved measurably.
Jim.....\BONZA Job mate
Not much achieved this weekend due to digging and the weather......
Did do:
Exchanged the ECU Box for an unbroken one, cleaned and satin blacked before refitting
Cleaned up, removed a little surface rust and painted the area under the ECU Box, waxoiled the area
Repaired some missing plastic loom covers.
On the To-Do list
find the oil leak, a little one showed up at Jim's from the cam cover I had done a few weeks ago, there is no sign of it today at idle or after a run !
x 8406
Delighted to hear how good things are on the hydraulic front Alasdair, that's excellent :D
Good on the ECU box, that really confused me when I was trying to put the lid back on!
That oil leak is funny. It was quite significant up here... Maybe the car is wise and much prefers to be at home in Somerset than up here in the Bucks Badlands...
x 1996
it is strange, not a drop on the ground after the run back and none when idling earlier :?:
x 8406
That is just so bizarre Alasdair...
x 1996
maybe that little "tweak" I gave it did the job, the socket hardly moved if at all ?
chinkostu
x 30
Unread post by chinkostu »
Stickyfinger wrote:maybe that little "tweak" I gave it did the job, the socket hardly moved if at all ?
Tried that once on a TU rocker cover bolt, sheared the stud clean off!!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1996
I already have two stripped threads needing HeliCoils next week
chinkostu
x 30
Oh dear Al, nothing too difficult i hope!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1996
They should be OK.
One was already gone (chemical metal in the hole) and the other was so worn that it gave way like butter. The leak strangely is not next to those and is bracketed either side by good ones
x 8406
The secret was in the use of a torque wrench on it... :wink:
I must admit, nowadays, on such delicate ones I always get the torque wrench out...
x 1996
This seat foam is FUBAR......so a repair will be needed
Over time the metal section pushes down, cuts the foam and in the end cuts the leather.
