Brakes
superloopy
x 19
Re: Brakes
Unread post by superloopy »
I used my activa mk1 vin details on service citroen to confirm genuine part numbers and then xreffed to mintex. I've also ordered a set of disks and pads for myself at that price as its too good to miss. Looks like clearance stuff but at the right price ... for me anyways. My disks (P reg 1996) are 283mm.
Sent from my LG-D855 using Tapatalk
Mike
KennyW
x 164
Re: Brakes
Unread post by KennyW »
Dave,
My Xantia is 283 mm discs if you require the calipers. They are still on the car.
Kenny
C3 1.4 petrol (SWMBO)
x 2941
Re: Brakes
If given a choice I would always use Ferodo rather than Mintex but I haven't had to buy any for a very long time so I'm not even sure they're still available.
I had a bad experience once on a big Austin Westminster using Mintex and have been a bit reluctant to use them ever since.
lexi
x 134
Re: Brakes
Unread post by lexi »
Gibbo2286 wrote:If given a choice I would always use Ferodo rather than Mintex but I haven't had to buy any for a very long time so I'm not even sure they're still available.
Not disagreeing Gibbo, however the compounds and specs of brake pad media have changed so much over the years. You cannot be sure what you are buying nowadays or where it is coming from. This means that all of these great names may be different from what they were, for better or worse. Some of the companies have changed hands too and are only there in name only. Even the steel on the discs and the combination disc and pad combined may have an effect. Minefield really and another reason for CIT OE if you are fussy. I have no bother with all sorts mind you but I don't drive on brakes much or at speed.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
lexi
x 134
Re: Brakes
puter problem
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8343
Re: Brakes
lexi wrote:puter problem
All the duplicates have been deleted Lexi...
Kept me busy for a bit...
daviemck2006
x 496
Re: Brakes
Unread post by daviemck2006 »
Mintex ones ordered and requested to be delivered to Jim's.
I don't need callipers, but thanks for the offer Kenny.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 8343
Re: Brakes
daviemck2006 wrote:Mintex ones ordered and requested to be delivered to Jim's.
Excellent!
I'll leave you to do the rears at some point Davie but I'm sure with new and decent Mintexes you'll find the brakes a lot, lot better. The rears will make little difference as they are hardly used in normal service; by far the most braking effort is carried out by the fronts...
daviemck2006
x 496
Re: Brakes
I have the discs and pads in the shed for the rears. That should be a nice simple job for me to do. (Famous last words)
Peugeot boxer 2016
In the family
x 2941
Re: Brakes
Just had a Google for Ferodo out of curiosity, I didn't realise they are now part of the Federal Mogul Group, We have a Federal Mogul factory locally, makes camshafts and the like for many motor manufacturers.
Some videos here that are probably worth a look for those interested:
http://www.ferodo.com/en-gb/ToolsServic ... ideos.aspx
x 8343
Re: Brakes
It is Davie, on the face of it but do look at all the threads on here about the fragility of the caliphate bolts and have some new ones on hand as a kind of insurance policy. If you have the new ones you just know then the old ones will come out without issue!
Do take care though... Those bolts can snap at the drop of a hat and if they do then it can be a whole world of pain...
BenC5HDi
Not Mike
x 45
Re: RE: Re: Brakes
Unread post by BenC5HDi »
CitroJim wrote:... here about the fragility of the caliphate bolts
Are they fragile because of the Allies bombing them?
Sent from my SM-N9005 using Tapatalk
daviemck2006
x 496
Re: Brakes
Thanks to all for the advice, and to xantiamanic for finding the links. I was looking for discs and pads as a set. I knew there were 3 different sizes. It's a bit confusing. The car should come back to me just needing an oil change, and the rear discs and pads done to be mechanically perfect. It will then need the small body issues done.
Peugeot boxer 2016
In the family
daviemck2006
x 496
Re: RE: Re: Brakes
CitroJim wrote:It is Davie, on the face of it but do look at all the threads on here about the fragility of the caliphate bolts and have some new ones on hand as a kind of insurance policy. If you have the new ones you just know then the old ones will come out without issue!
Are those the bolts holding the callipers on Jim? Do they go right through the calliper the same as the c5 ones? I had a hell of a job with my first c5 and ended up just changing the pads and leaving the discs.
Peugeot boxer 2016
In the family
BenC5HDi
Not Mike
x 45
Re: Brakes
They are Davie but I seem to remember Chris already dealt with them once so hopefully they should be ok.
