It just says 'Windows XP, Home Edition, Version 2002, Service Pack 3 - no mention of 32 or 64GiveMeABreak wrote:Right-click on 'My Computer' and choose 'Properties'. In the information screen, it will tell you if you have a 32 or 64 bit OS installed. I just want to eliminate some possibles.c5rich wrote:Hi Marc, I know it is Windows XP, not sure where to see if it is 32 or 64bit?GiveMeABreak wrote:@C5Rich - Rich, can you please confirm what Windows version you are running on your laptop is and whether it is 32 or 64 Bit?
Merged Lexia & Diagbox threads
c5rich
Re: Merged Lexia & Diagbox threads
vborovic
- Locked user account
- x 40
It is 32-bit ... in the case of a 64-bit XP, it would be written next to the OS title
- x 6957
That's ok then, it is the 32 bit version, which eliminates some possibilities.
I assume you installed it with admin rights and that this was a clean installation of Diagbox (i.e. you're not installing this over another version / or over a previous failed installation? If so we need to clean the previous installation thoroughly before reinstalling. If you have only installed it once, did you get the software activated when you installed the version 7.01 / 7.02? When you launch Diagbox, it should say 'checking for activation ....' if it is activated the message should disappear. If not activated you will keep being asked to activate.
If the above is ok:-
There could be several other causes for the error, and in order of the least hassle, I would suggest the following:
It is possible that you have a bit of malware or a virus that is blocking certain functions. I had somebody who had a virus on their Lexia laptop that was interfering with the software and the same issue was happening. After cleaning the virus all was well. You can follow this link if you want an offlline checker from Microsoft without actually installing a virus checker onto the laptop:
http://windows.microsoft.com/en-gb/wind ... er-offline
Download the 32 bit version of the tool. It is an offline scanner that will guide you through creating the media. If you have a spare flash drive, use this. It would help if you can make sure the flash drive is virus free - ideally a desktop PC with a virus checker on to scan the USB flash drive. Follow the instructions and let it boot off the flash drive and check the laptop.
If this comes up clean then I would suggest a thorough removal of Diagbox (there is a Diagbox Cleaning Tool) that will remove the folders and the registry entries of the software. If you want some help let me know and I can do a dial in with you using Teamviewer:
https://www.teamviewer.com/en/download/windows/
Just send me a PM with the code and password.
c5rich
Hi Marc, thanks for all the advice. Yes I installed it with admin rights (I installed the Diabox via the video on the set up DVD sold with the Actia). Apparently windows defender can't be use 'on my operating system' !GiveMeABreak wrote:That's ok then, it is the 32 bit version, which eliminates some possibilities.
- x 6957
unfortunately there are less and less programmes being supported on XP now since being de-supported by Microsoft for some time. Is Windows 7 an option for you? If it's going to look like a reinstall it might be worth you considering Windows 7 at the outset. Do you have a Windows 7 32 bit Disk? If not you can download the media file easily and legitimately, you just need to buy a key for activation. You can buy one from companies scrapping their older hardware for about £10. Send me a PM if you want the details Rich.
BenC5HDi
- Not Mike
- x 45
Can someone please tell me what I have, and what version of software I need, because it doesn't work with 7.02. I simply get "NO" in Lexia for dialogue with all the ECUs.
It says 9780.Z5 on the top , and ACTIA PSA XS Evolution "made in France" on the bottom, with a long serial number of 921815B/29W07/0004526
It's Malcolm Citronut's old Lexia, so we know it worked - I have misplaced the disc that came with it, and it doesn't want to know with my newer versions of the software.
Help!
Help!
BenC5HDi
- Not Mike
- x 45
To answer my own question, it's one of the Lexia kits bought at the start of this thread by DickieG, Jim and more. That must mean I need a copy of V4.5 that originally came with these machines, if anyone can supply one, that would be excellent.
BenC5HDi
- Not Mike
- x 45
So, does anyone have a set of activation instructions for Diagbox 5.02? I've searched all over the place and I'm getting nowhere at all.
I can only use up to 5.29 with my Lexia hardware.
If anyone can help me activate 5.02 - I have downloaded it from Mandrake's link earlier in this thread, and it installs fine, I just have no activation instructions at all. Google isn't proving much help, apart from sending me to dodgy sites to download small patches.
Failing that, does anyone want to buy an earlier Lexia and sort it out themselves ? :/
- x 6957
Ben, from what I can tell:
DiagBox v7.02 needs Lexia 3 Interface Firmware = 4.3.0
DiagBox v7.57 needs Lexia 3 Interface Firmware = 4.3.2
DiagBox v7.58 needs Lexia 3 Interface Firmware = 4.3.2
DiagBox v7.62 needs Lexia 3 Interface Firmware = 4.3.3
DiagBox v7.66 needs Lexia 3 Interface Firmware = 4.3.3
DiagBox v7.74 needs Lexia 3 Interface Firmware = 4.3.3
DiagBox v7.76 needs Lexia 3 Interface Firmware = 4.3.3
I assume you have used the PSAVersion Checker to see what firmware / revision you have first of all?
- x 3566
I've got install instructions for 5.20 from Easydiagnostics from a good few years ago. This would be for an XP install. Let me know if you want me to PM them. I've probably still got the ancient(!) discs if any use.BenC5HDi wrote:So, does anyone have a set of activation instructions for Diagbox 5.02? I've searched all over the place and I'm getting nowhere at all.
c5rich
If anyone is interested, I have my Lexia kit up for sale > http://www.frenchcarforum.co.uk/forum/v ... =7&t=54761
- x 2000
Lexia is not talking to Pug 307 ?...any thoughts
I have been asked why a 307 would throw a Anti Pollution fault after a rubber mat got stuck under the throttle.
Any comments ?
.............I have one with 7.02 installed
Code on the dongle/unit is 9780.Z5
Should I update it ?
Any comments ?
- x 6957
I take it this isn't a wind up? - A few days late for April Fool!Stickyfinger wrote: I have been asked why a 307 would throw a Anti Pollution fault after a rubber mat got stuck under the throttle?
Back to the Lexia though - what year is the 307 Alasdair, and secondly what Operating system are you running Diagbox on and also is it 32 or 64 bit?
Make sure economy mode isn't active - run first test with engine running if not already tried.
If it's not playing nice, it is well-known that some kits won't talk to the 307s and may possibly need a firmware upgrade.
Do you have the PSA version Checker? If so this will tell you the Chip revision and the Firmware - if you need this prog. let me know.
Once we've established the firmware and chip versions I can guide you through updating the firmware, but we need this info first in case it goes
I have all the files needed for the firmware upgrade, so just let us know the above info first Alasdair.
- x 2000
Hi Marc...it is way past the 1st
its a 03 2ltr 307
OS is Win7 32bit on my Sony Vaio, works perfectly with my C5X7
Do not know what the PSA checker is, so I think I need that then
its a 03 2ltr 307
- x 6957
Here's the link and instructions from my previous post for the PSA checker Alasdair:Stickyfinger wrote:Hi Marc...it is way past the 1st
its a 03 2ltr 307
http://www.frenchcarforum.co.uk/forum/v ... er#p482940
When you have that info we know what firmware to try.
