Problem ahead
x 5652
Re: Problem ahead
I have had a bit of that on both C5s - quite alarmingly so on the first one.
In both cases injectors.
Cleaned and refurbished they run fine now.
x 1929
Re: Problem ahead
On the old idi engines that's a sign of heater plugs needing replacement. Not so for modern di engines (and you've had them replaced anyway) so I would suspect injectors letting the fuel in at too low a pressure. Have you done any live reading of the injection system at all?
c.morewood
x 55
Re: Problem ahead
Unread post by c.morewood »
When/if I buy the works hdi, I'll swap injectors next winter and prove/disprove the old injector theory. I have 8 injectors and have changed them round to try to equalise them on the lexia. When she's warm she starts fine and the water heater makes sure she's warm when at home in the winter.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
superloopy
x 19
Re: Problem ahead
Unread post by superloopy »
What's an 'idi' engine?
Sent from my LG-D855 using Tapatalk
Mike
x 5652
Re: Problem ahead
xantiamanic wrote:What's an 'idi' engine?
Indirect Injection - squirts into a precombustion chamber.
superloopy
x 19
Re: Problem ahead
Thanks steve ... so an old type like an xud, yes, as opposed to an hdi?
Mike
x 5652
Re: Problem ahead
Yep!
x 1929
Re: Problem ahead
Apologies for the TLA.
lexi
x 134
Re: Problem ahead
Unread post by lexi »
Just to bump this back up again. Haven't done anything yet as problem has been gone. This morning on turning ign on, I got the beep and the warning lights. Back to old symptoms of starting with a splutter and smoking . Watched my temp gauge this time and sure enough........the needle swung up to hot and then instantly back down again. IME that is faulty temp coolant sensor. New one is here so will fit ASAP when carport and shelter are available.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
