Anyone done one? any hints and tips or things I should change while i'm in there?
Cheers gents
c3 1.6 hdi clutch swap
Chris570
- x 36
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 1484
Re: c3 1.6 hdi clutch swap
It's not a lot of fun....http://www.frenchcarforum.co.uk/forum/v ... =3&t=54045
Likely on a C3 you will need the subframe out. Flywheel, clutch, release bearing at the least, and quite probably the input guide tube and release arm to go with it. Parts likely over £500....
Chris570
- x 36
Hmmmm, it's a solid flywheel on this one (Yay!) if the subframe has to come down i'd be tempted to let a trusted clutch place do it as i'm pushed for time at the moment!
Is the tube and fork a common item for wear then?
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
