1.9TD cold start
Post Reply
Harlequin
Donor 2023
My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6
x 24
1.9TD cold start
Post by Harlequin »
hola , checked my cold start cable this morning (bosch pump) and at minus 3 it was slack? what do I need to check to get it working again?
ken newbold
My Cars: Peugeot 806
Citroen C3 1.4 Hdi
x 4
Re: 1.9TD cold start
Post by ken newbold »
Probably a new one. You could try taking up the slack, but you'll most likely find it's on all the time afterwards.
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
Harlequin
Donor 2023
x 24
Post by Harlequin »
well the cable moves freely so I'm thinking its more the vacuum side
Harlequin
Donor 2023
x 24
Post by Harlequin »
aha - located it - the vacuum is working , but the cable is not being pulled tight enough to operate the fast idle - too much slack in the cable.
Harlequin
Donor 2023
x 24
Post by Harlequin »
oh bugger - whilst turning the adjustment screw I slackened not tightened - and its slipped off ! argh - does anyone have the route the cable goes on the back of the bosch fuel pump
Harlequin
Donor 2023
x 24
Post by Harlequin »
sorted but , when I push the fast idle as if the cable is taut - the revs drop - is that right?
ken newbold
Citroen C3 1.4 Hdi
x 4
I doesn't sound right. I could post a pic of mine tomorrow if it helps
Harlequin
Donor 2023
x 24
Post by Harlequin »
thank you would appreciate it
MikeT
My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon
x 231
Post by MikeT »
Harlequin wrote:sorted but , when I push the fast idle as if the cable is taut - the revs drop - is that right?
IIRC, that is normal, yes. If you look at the two idle settings arrangement, they're connected by a lever (think rocker switch) where either one side (cold-idle) or the other (normal-idle) is in effect. At rest and without counter force, the pump's springs tension ensure the cold-start is always "default" and requires a force to pull back the lever to the normal-idle setting which is the job of the cable and it's attached device (be it a waxstat - early models, or solenoid - later models) via a vaccuum force as the engine warms up.
Harlequin
Donor 2023
x 24
Post by Harlequin »
Harlequin
Donor 2023
x 24
Post by Harlequin »
reconnected a loose vacuum pipe but even wound all the way tight there appears to be a lot of slack in the cable
MikeT
x 231
Post by MikeT »
If the cable isn't being operated when the engine warms up, check the vacuum supply. The vacuum pump is on the end of the camshaft, feeds into two solenoids on the bulkhead.
The solenoid is often the culprit.
Harlequin
Donor 2023
x 24
Post by Harlequin »
i think it is being operated - its just even wound all the way tight , the cable has a lot of slack.
can I fit a shim or spacer to give it less slack?
MikeT
x 231
Post by MikeT »
Harlequin wrote:i think it is being operated - its just even wound all the way tight , the cable has a lot of slack.
I can't answer that, sorry but I would urge you to confirm the cable is being pulled, as I say, it's common for the solenoid to fail
Harlequin
Donor 2023
x 24
Post by Harlequin »
ok - which solenoid and where will I find it?
Post Reply
