Not quite, but I fixed it for you - just click on the 'direct' box on the page and then paste that into the IMG tags.
If that part is squeaking (are you sure it's that part and not the actual clutch?) the I can only see that it will have to be replaced.
Noisy Clutch !!
- x 1485
Re: Noisy Clutch !!
flying clutchman
- x 3
Re: Noisy Clutch !!
I once fitted a new clutch to a peugeot 308 (very similar setup) which was suffering from this squeak as well as having a knackered clutch. I changed the dmf and clutch and made sure I lubricated the fork pivot stud as well. The clutch was fine but it still had the squeak!
