Fickle thing that it is ...
new addition to fleet
jgra1
- (Donor 2021)
- x 36
Re: new addition to fleet
Car fine again..
jgra1
- (Donor 2021)
- x 36
I will make an effort to understand H3+ ..
the symptoms I think I have are along these lines:
If one of the front wheels goes into a dip/manhole etc that front corner drops in, the opposite back corner lifts up.. i.e. a diagonal movement.. this feels odd.. (not sure if this is both wheels or just one)
If one of the (possibly rear) wheels goes into a dip/manhole, the back of the car shakes sideways, as do the occupants.. - shimmies
The steering seems slightly heavy, but more so it doesn't really want to turn in - hard to explain, it just seems to not want to corner.. certainly it doesn't corner with ease and trueness like SF's does. (this could be tyre/wheel size) - the car also seems to understeer more than I would have expected..
The back does feel a little underdamped, although its not different from SF's tourer.. just a reverb from the back end after a bumpy bit of road..
some of these are just part of owning a very soft and quite new hydro X7, and that is fine, some of them maybe show a problem.. my first thought was a mechanical issue, a loose roll bar or too much rear wheel lean in.. it didn't occur to me to think mismatched spheres/ electrovalve issues etc..
The car had 1 or 2 new struts 2 years ago (a 4 year old car! ).. I don't know if the spheres were replaced.. the paperwork just says serious oil leak Nearside Strut, mot fail
would a lexia help tell me if the suspension was ok, or be able to test anything? I haven't tried as yet.. getting her to run was the main job of recent weeks
thanks as always , John
I may get someone to make some video of the poor car driving along from an external point of view
and
its quite something, this suspension.. complex though and my mind is already wondering about small bits within struts and computers and so on..
and
KennyW
- x 165
John,
Over the years I have found it is usually the smallest simplist thing which causes the problem.
Like you I'm new to the X7 and H3+ and will have to do some reading up.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 1994
BL Autos John, get them to test drive it.....they must of driven lots with the C6 work they do.
jgra1
- (Donor 2021)
- x 36
Thanks both.. will get tracking checked I think locally and also put lexia on later see what's what .. will see about bl
jgra1
- (Donor 2021)
- x 36
I finally got the lexia on the X7 last night..
a selection of faults logged but I was interested in the suspenion... I had a C1146 'rear body height sensor fault' and a U2005 'triggering (vehicle speed receipt anomaly)'
I cleared them and the car actually seem twice as good as normal, to the point i couldnt relly detect any odd body roll.. it could just be hawthornes law or what it's called..
I will recheck for errors later..
- x 1994
|L:egacy from the broken dog bone I bet.
BSI reset with a FULL battery : Log on Lexia, Clear all faults. BSI reset then a 1/2hour drive: then log on again and see what you have fault wise.
Getting there mate:)
