C5 x7 steering rack leak
- x 1982
Re: C5 x7 steering rack leak
I wish we lived in the USA and could take a "class action" over such design failings
- x 6963
Yep - I hear the US already has a minimum life / tread for car tyres expectation for consumers - they should bring that in over here for sure.
- x 1429
It might be a good idea for those with racks that are not yet leaking to spray some grease around the shaft.
vborovic
- Locked user account
- x 40
@ jgra - I think the leak occurred between the pinion housing and the rack housing ... the guy knows his stuff (although quite young), and said that he uses kits with full rubbers and seals, and that the entire unit will be sand-blasted, and after he's done, the pinion shaft will be enveloped in a protective grease-like substance, that should be hard to take off with average road conditions ... the job should be completed by wednesday noon ... I'll post photos of the reincarnated steering rack, just to give people some before-after opportunities for evaluation ... if I could get 3 years of life out of it, that would be a great deal IMO
jgra1
- (Donor 2021)
- x 36
good stuff VB, for some reason I thought the problem was a seal at the outside of the Pinion Housing..
vborovic
- x 40
Actually it couldn't, the constructors, for whatever reason, disabled this possibility by putting this on the back side of the pinion part:Stickyfinger wrote:I am thinking a gaiter or the correct size could me obtained and fitted to avoid the corrosion ?
That point gets attached to the chassis, or wherever ...
- x 1982
What about paint on "Rubber paint" or an PV sealant ?
vborovic
- x 40
Here's how it looks like repaired (already collected today), there is high likelihood that tomorrow the car will be on the road by the end of the day.Stickyfinger wrote:What about paint on "Rubber paint" or an PV sealant ?
- x 6963
What about all that rust?..... oh it's copper grease
Lighty
- x 35
Looks like a good repair
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
vborovic
- x 40
Will let you know in two years' time ... hopefully, three ...Lighty wrote:Looks like a good repair
- x 1982
Is the shaft full exposed all the time then ?
old'uns
- x 127
apparently so according to my garage.....mechanic reckons for some reason Citroen placed the rack further away than usual which means that where the shaft/UJ etc is tucked partly into bulkhead/floorpan for protection, on an X7 this is now exposed.
i'll assume there is a 'good' reason why Citroen designed it this way but.....................maybe the designers were good friends with VW software engineers ie people with a grudge against the Co.
- x 1982
I still cannot see why it cannot be sleeved in some manor to protect it at the seal. There is no pressure after all......just cannot get a pic in my head of it
- x 6963
I'm sure both my Mk1 & 2 C5 racks were covered in a thick plastic sheeting. Never had any issue with either of those.
