Noisy Clutch !!
Chris_H4922
Noisy Clutch !!
Unread post by Chris_H4922 »
Since the weather has changed and we have had some colder weather my 2009 C5 tourer has gained an annoying noise. Cant put my finger on it and it is beginning to bug me. Can anybody help me as to what this may be and is it a problem I could potentially fix? I have posted a link to a video.
Many Thanks for reading.
x 1998
Re: Noisy Clutch !!
Unread post by Stickyfinger »
That sounds like dry joint/rubber to me
A little DOT4 (use a small brush) or some sort of "rubber lube" on the rubber and 3-1 in the peddle bearings as the first effort I would think.
Chris_H4922
Re: Noisy Clutch !!
Stickyfinger wrote:That sounds like dry joint/rubber to me
where am I looking on this diagram?
x 1998
Re: Noisy Clutch !!
3 8 9 10 and the rubber boot on the piston....recorded inside the car right ?
Chris_H4922
Re: Noisy Clutch !!
Stickyfinger wrote:3 8 9 10 and the rubber boot on the piston....recorded inside the car right ?
I eld the phone outside the drivers window. but yes you can hear it the same inside with windows closed
x 1998
Re: Noisy Clutch !!
Worth a first look....and its dry inside the car :).....sounds rubbery to me so may also be the slave cylinder rubber. Does it do it with the engine turned off ??
Chris_H4922
Re: Noisy Clutch !!
Stickyfinger wrote:Worth a first look....and its dry inside the car :).....sounds rubbery to me so may also be the slave cylinder rubber. Does it do it with the engine turned off ??
I will have a good look around tomorrow. and yes it makes the noise with the engine off.
x 6946
Re: Noisy Clutch !!
I wondered what was going on in the video! - but once I turned my speakers on - sounds like mine was for a while - every time I engaged / disengaged the clutch I would get the same sound - got annoying, so just asked the dealer to look at it when it was in for servicing (to maintain warranty) and it was as Alasdair says - just needed lubricating. :-D
Chris_H4922
Re: Noisy Clutch !!
GiveMeABreak wrote:I wondered what was going on in the video! - but once I turned my speakers on - sounds like mine was for a while - every time I engaged / disengaged the clutch I would get the same sound - got annoying, so just asked the dealer to look at it when it was in for servicing (to maintain warranty) and it was as Alasdair says - just needed lubricating. :-D
definitely try and remedy the problem with the recommendations.
Chris_H4922
Re: Noisy Clutch !!
I had a good look and listen today and you can barely hear it in the cabin. less than initially. Still as loud outside.
Chris_H4922
Re: Noisy Clutch !!
https://www.facebook.com/photo.php?fbid ... =3&theater
I have finally found the culprit. Anybody have any idea how to remedy this?
Many thanks in advance
x 1496
Re: Noisy Clutch !!
Can't access the links....
Chris_H4922
Re: Noisy Clutch !!
How do you insert pictures. Can't work it out?
x 5674
Re: Noisy Clutch !!
Chris_H4922 wrote:How do you insert pictures. Can't work it out?
Guide here.
Chris_H4922
Re: Noisy Clutch !!
hopefully that has worked :)
