C5 electrical issues (poss bcm?)
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
Re: C5 electrical issues (poss bcm?)
Clean it all off with Isopropyl, make sure it's nice and dry then spray on some circuit board lacquer to seal it up.
Lexia ponce
Lexia ponce
- My Cars: in order of the pain they cause me......
2005 Berlingo Multispace 1.9D
2005 Honda CRV (stopgap until berlingo is sorted)
2009 Toyota Avensis - x 1
yes i shall be down to maplins for a can of finest servisol tomorrow the dialogue bit is connecting to every bit of the car except the suspension computer on the global scan and its showing when I scan the BSI on its own. I just hope we're on the right track with the deadlocking and changing it to simple locking when it scanned the door sensors it read the fronts ok both opening and closing and the rear doors are registering closed (as they are) when you activate the locks via lexia the fronts lock fine but using the unlock button on lexia doesnt work, same as using the remote.
@ stempy yes thats what i did with the isopropyl and then buffed it to a fine shine, it was that green and grey crud you get when a AA battery leaks
Sounds like you're on the right track (pun intended). I'm happy as mine passed the MOT today, albeit at the cost of two new front tyres.
Lexia ponce
Lexia ponce
i have until the 16th of feb then its due and i gather that the doors need to open and shut for the mot so fingers crossed its done before then if not then i'll have to crowbar the doors lol i dread to think what faults the MOT will drag up i'll sort the leccys then there will be more work its almost a full time job owning a citroen
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
I think we've got the world's entire WD40 experts as members on this forum, Cracking!
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Try it on your PC's motherboard
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
From what I have read, WD40 was developed for the American missile forces. The ballistic missiles had to have the tanks fully fuelled (to provide the rigidity, otherwise the missiles collapsed under their own weight), but they had to protect them from rusting. They started looking at ways to keep the water off the fuel tanks, and (after a lot of testing) Water Dispersant formula 40 produced good results. When it went to market it was initially sold as Rocket WD40.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Based on fish oil
Lexia ponce
Lexia ponce
afternoon folks
no joy with the dutch for that replacement unit, they say that 9637466180 is actually the code for the black plastic bit and not the actual BCM think theyve been at the wacky baccy
Lexia ponce
Lexia ponce
thats the fella! tyvm stempy got to be worth that the dutchies were gonna charge me 95 euros for one that may or may not have worked!
are there any cheaper places than bcm-reman to have it virginised?
If you have the whole kit you should find it will just work.
Lexia ponce
Lexia ponce
wont the ecu be different though as its off a different model will it really be as simple as that? fingers crossed it will be as its cost a damn site less so far best quote ive had for virginising is £105 and i only paid £250 for the car lol
There's one way to find out. I would guess that they will be different, but how different I wouldn't like to say. There are many folk here far more knowledgable than me on the subject who will probably have the answer, I'm dieselphobic myself.
Lexia ponce
Lexia ponce
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I've checked up for you on the service docs and the 2.0 110 HDi and 2.2 136 have the same part number for the BSI: 6580 H6 and 6580 H7. Not sure what the difference is between the 2, the H6 says 'configured part and VIN to be specified on order' and the H7 just says 'part to be configured.
The only other difference is for a 3.0 and that is the same part number with 2 different letters, so I think it's a safe bet the 2 are interchangeable.
