My friend's C3 has been playing up last week. Going into limp home mode and engine fan going full blast. He managed to drive it to his local garage but they didn't have the Lexia kit and couldn't work out the issue. He was therefore going to get it booked into the main Citroen dealers next week. I went to the garage on Friday with my Lexia and diagnosed it with code P0485 (Cooling function incorporated into engine ECU permanent fault) I managed to clear this fault and he drove it home about 3 miles carefully no problem.
Today, he decided to take it to the local petrol station to get some fuel when it went into limp mode again, but he managed to drive it home. I called up today with the aim of resetting it again ready for him to try and drive it to the main dealers next week, but for some reason (maybe unrelated) my Lexia started a diagnostic but there was no communication with the BSI or any ECU. While we were trying to run the diagnostic, he had the engine idling for a while (in case the Economy Mode was kicking in and playing up), but the engine warning light came on again and the Engine Temp too High warning with it. He switched the engine off and went outside to hear the car gurgling away. We carefully lifted the hood and coolant was bubbling out of the expansion tank all over the place. It was a rusty brown colour. Nothing was leaking out of the radiator or any other hoses. When the gurgling had settled down, I carefully checked the expansion tank cap and confirmed it was on tight.
His local independent garage did an engine rebuild last year after the cam belt went - but when I asked whether they replaced the water pump - he didn't think so - awaiting confirmation on Monday.
So - obviously there was nothing wrong with the temperature sensors - they seemed to be doing their job properly!
My initial thoughts are:
Failure of water pump?
Head Gasket Failure?
Has anybody had something similar happen and if so, what is the likely prognosis and potential cost? The issue now for him is how much is it estimated to repair against the value of the car, against needing to get it running to do anything with it.
Any pearls of wisdom gratefully received in advance
