The Citroen "cool picture" thread
- x 2000
Re: The Citroen "cool picture" thread
Done it Jim, lights are better, but dark country road, on-coming traffic, wet....still crap with bugger all penetration, dreadful things.
- x 8370
Ahh well, Put some big rally-like driving lights on it then...
Don't want you knocking down any innocent badgers now, do we!!!
- x 2000
BADGERS !....who said Badgers !
- x 8370
Xantianut
- x 124
I put some rally lamps on my BX16TRS. Raydot Fireballs to b be precise and with those switched on, I could see into the future!
RIP
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
RIP
BX19DTR (Fifi 2)
- x 2000
The Dip is the big problem......
Note to self:
I MUST get those lens (clear) replacements done and the units fitted up with projectors...must must must
Note to self:
daviemck2006
- x 496
I soppose I will soon find out how poor xantia lights are. My 107 are ok, but nothing special, the 205 headlights are fantastic! No fancy styled narrow stupid shaped lights, just big square lights with halfords super brilliance bulbs in them, and correctly adjusted. The problem with extra spotlights is they may improve main beam, but no help on dip at all, where your lights are on most of the time.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 8370
I'm not 100% impressed with my C1 lights either Davie...
I you think Xantia lights are bad then try XM lights... Real Toc-H lamps those and in truth I've seen brighter glow-worms...
Xantianut
- x 124
Ay up!
I never had a problem with Xantia headlights, at least not after making new bottom mountings from sheet brass. Before discovering this, I found the main beam gave a similar pattern to what I Would expect on dip. Dip beam? Least said soonest mended!
Once I fixed the lower mountings, penetration was better than on the BX. The mountings are very thin, fragile bits of plastic on the lower mouldings that go brittle quickly, I would think reinforcing existing mouldings would be easier than fixing broken ones. I also found just Araldite gave a short term repair so I needed to reinforce the patch with some panel pins or similar. Self tappers should also work.
RIP
BX19DTR (Fifi 2)
RIP
BX19DTR (Fifi 2)
- x 2000
My mounts are not broken and the headlamps are aligned (by the garage laser machine thingie).
Got some Al sheet yesterday and a template made in card ready for modification.
The soft vacuum applied reflective surface does not help them that's for sure...NEVER Touch it !...EVER
HansNOR
- x 7
- x 8370
Pictures of SMs are always very welcome Hans
- x 8370
I love that picture of the old petrol pumps with a 2CV behind... That's worthy of a Microsoft Bing or Windows 10 background picture...
Those lowered 2CVs I'm not so sure about....
HansNOR
- x 7
I think it might be a Dyane behind the pumps. I like them high and low - but it needs to be on air so it is still functional. (or you could do hydraulics
