Xantia sill end plug
x 8406
Re: Xantia sill end plug
wurlycorner wrote:Ok, pm me your address and I'll get it out to you sometime in the next week.
Done! Thanks Iain :D
x 1995
Unread post by Stickyfinger »
I have a set x5 on "Back-Order"....but when have I ever ordered anything and not had it on back order ? :)
x 8406
Somerset is far, far away Alasdair... They need to find some cargo badgers to bring them to you and that's what takes the time...
x 1995
Who said Badger !!!!
Is that a Bird ? i
s that a Plane ?,
might be a Badger on springs
Open your eyes
Look up to the skies and see
It's just a F'ing Badger, I need no sympathy
Because he's easy shoot, easy go
A little high, little low
Anyway the wind blows, doesn't really matter to me, to me
Pedersoli, Pedersoliwill you use the Sabatti
Thunderbolt and lightning - very very frightening me
Tanfoglio, Tanfoglio,
Tanfoglio and hollow point - magnifico
x 8406
He's working out how to get to you via astro-navigation...
ksanturion10
x 19
Unread post by ksanturion10 »
Stickyfinger wrote: 29 Dec 2015, 16:50 could be, but I only have remains for something that has then been stuck on with sealant/adhesive.
Zero rot inside and everything good/clean/original and even blue paint :)................I think its water it is not used to and it has just washed off :)
EDIT:
Found it on Citroen service
Rear Entrance Plug......tittter titter giggle
OK, better late than never, but still it is too late :-D .
Asked at the local PSA about price for 96130325 - was told that there is no such item =D>
Saw it in the range of 4 to 10 euro/piece :shock:
Just need to know in advance, before trying to pull it off, 48,4 mm x 48,4 mm are the dimensions of the hole into the body or the outer dims of the plug - item 05 from the picture?
Any info would be appreciated.
BR
Martin
Only himself the stupid makes wrong, many are being confused by the clever :P
