Brake fluid.
qprdude
- x 14
Brake fluid.
Just noticed the brake fluid level is about 20mm below max. Not a problem I know, but I'm off up to Stoke tomorrow and would really like to get some dot4 to take with me. No sign of any leaks anywhere obvious certainly nothing on the lockblock driveway . Could be weeping somewhere but a quick look shows nothing. Seems to be a lot of different brands and prices. Is there any advantage in paying top dollar, or is the cheaper just as good.
Rick.
2013 Citroen DS 5 D/Sport
- x 1988
Re: Brake fluid.
That will be your brake pads being low.....change will be due soon, mine drops to the Low level line when worn then back up to Level when I changed them just before Christmas....if you top up, it could/will spill when you put new pads in.
wurlycorner
- x 271
Re: Brake fluid.
On a normal road car, you're very unlikely to notice any difference between brands of brake fluid.
Iain
CX DTR T2 Safari (silver)
Iain
qprdude
- x 14
Re: Brake fluid.
OK. The pads will have to wait a few weeks. Nothing wrong with the braking, and I'm not really hard on brakes normally. These have been on since I bought the car in July 2012.
Rick.
- x 1988
Re: Brake fluid.
LOL, they have done well.
Just check the thickness, you can see through the wheels
qprdude
- x 14
Re: Brake fluid.
I'll probably get a price from a local Indy. There is on in Weybridge, which is about 10 minutes away. Unless someone knows another one? Not priced the parts yet.
Rick.
- x 1988
Re: Brake fluid.
I would fit OEM Pads over after market personally, not cheep but they last for you so over 3-5 years, good value
Indi should fit them in about 15-20 mins
Bick
- x 44
Re: Brake fluid.
Citroen do fixed price pads and discs for £250 per axle i believe.
qprdude
- x 14
Re: Brake fluid.
Too rich for my blood. Wasn't thinking of discs unless absolutely necessary. Skimmed the ones on my last car but I'm not in engineering now so hoping discs will do for now. I am expecting to hear the short intake of breath and " fraid the discs are knackered sir," anyway, hence the use of an Indy rather than a dealership.
Rick.
qprdude
- x 14
Re: Brake fluid.
Faultless run up to Stoke and back. Crappy MPG though, but I wasn't hanging about. 44.4 up and 41,0 back.
Rick.
