Xantia radiator woes and bootlid alignment question
mirafioriman
Unread post by mirafioriman »
Next problem my radiator is leaking :roll:
No one in the UK seems to have a new one. Seems like you need to get one from Denmark or Holland.
Does anyone have a good used one? It's a 1994 1.9d manual non air con car with the expansion tank up the drivers side of the rad when sitting in the car. Seems to have one large coolant hose each side and a smaller hose to the oil cooler on the driver's side.
Is this radiator common to other Citroen cars like the ZX and C15?
Secondly, the gap between the top of the hatch and the back of the roof. How wide should it be?
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
x 1450
Re: Xantia radiator woes and bootlid alignment question
Unread post by xantia_v6 »
There might be cheaper elsewhere, but they are available: http://www.ebay.co.uk/itm/Nissens-Radia ... 1758128370
mirafioriman
Yes that's the one in Denmark
x 1450
check your RP number, because there was a change at 6356 to:
http://www.carcooling.co.uk/products/Ra ... 36-50.html
mirafioriman
The one in the link isn't the right one as it doesn't have the built in expansion tank that mine has.
Zelandeth
x 1593
Unread post by Zelandeth »
Worth checking if you've got a radiator specialist local to you. It may be possible to get your existing rad re-cored, though less companies are willing to do work on plastic tanked ones unfortunately.
Current fleet:
tim leech
x 12
Unread post by tim leech »
Maybe the from 1.8 petrol may fit? The BX non turbo diesel and 1.9 Petrols were the same.
http://www.ebay.co.uk/ulk/itm/252219018157
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
