Looking at a(nother) xantia on autotrader HDi. No pictures of under the bonnet to.spy the extra pipe so just wondered if anyone can identity if it's 90 or 110 hp from the reg. It's Y281fce
I know.I.already have one, but the more the merrier right
If you re-read the advert on Autotrader it states 110 HP but there is another way.
Using either GSF or ECP websites, input the reg. number and then check the details for front brake disk dimensions. The 110 Xantia uses 288mm diameter disks, the 90 uses 266mm dia.
Thanks for the info. On the mobile app for Autotrader I couldnt find the 110hp, but it was on the desktop when i looked a couple of days later on my laptop.
I had clocked the wiper removed on a well maintained car and thought it a bit odd, however,
Sadly it sold before I could have had the chance to get down to Southampton. It would have been ideal as it's exactly the same as my Xantia, so mine would have been a donor for it or vice versa depending on condition etc. Mine unfortunately needs a fair bit of work doing to it now, so looking around for a cheap stop gap so I can take mine off the road and work on it without Monday morning pressures!
Ive a hdi 110 exclusive in maroone.. 181k but we all know these 8v hdis do 250 easy.. on Vsx alloys and a T plate. Not long had mot about 5 months ago.. looking around 425.. some laquer peel on nearside wing but might have found another...
Ooh, an exclusive, sounds tempting! Is the car in North Wales as per your signature? With the birth of our second child 6 weeks ago time available to go on cross country jaunts is rare and unpopular. Do you have any photos please?
You don't happen to be passing through Gloucestershire anytime soon do you?!
