Clutch
RPWC
x 21
Clutch
Unread post by RPWC »
Where is the clutch master cylinder on the Dispatch Mark 1?
Cheers Rich :wink:
x 6954
Re: Clutch
There are 13 types of Dispatch footprints (excluding the different engine sizes), so you would need to be a bit more specific:
Cab Floor - Long Type 8
Cab Floor - Long Type 9
Cab Floor - Short Type 9
Mixed Van - Short Type 800
Panelled Van - Long Type 800
Panelled Van - Long Type 900
Type 8 Platform Cab
Type 800 Short Side Window Van
Type 800 Van Short
Type 900 Short Side Window Van
Type 900 Van Short
Windows Van - Long Type 800
Windows Van - Long Type 900
If you PM me your VIN, I'll be able to look it up for you, as there are some models that are not listed with a clutch master cylinder at all!
RPWC
x 21
Re: Clutch
Hi Marc, thanks for the reply it's a 2004 short wheelbase panel van. Haven't got the V5 handy for the vin no ,but pm coming with reg number
Cheers Rich :wink:
x 3295
Re: Clutch
You can normally find the VIN number on the vehicle itself, either on one of the wing lips, and (on later vehicles) through a small window in the lower blacked out area on the windscreen (usually lower left).
x 6954
Re: Clutch
Richard - PM sent with all the info you should need.
x 6954
Re: Clutch
Hi Richard, yes the Clutch Master Cylinder uses the same fluid from the brake reservoir. You can see the pipe (part 9 on the diagram) from the reservoir to the clutch master cylinder and then onto the clutch slave cylinder via clutch control pipe (11). You can bleed the slave cylinder from the nipple (I think this is near the front of the gearbox).
