Easy on the 1.6ltr C5, just scrape off the bits from the injectors/turbo feed/valve and feed it back inCitroJim wrote:The Bosch 1.9TD is great like that. If it can be pumped and is vaguely ignitable by compression then its happy...KP wrote:Stu I've run so much horrid stuff thru 1.9tds over the years I was surprised they still ran when I sold them! Straight unfiltered waste veg, engine oil that was horrid, lhm, brake fluid, trams fluid....
Remember that Rudolph Diesel always intended his engine to run on anything but petroleum derived fuels.. He liked coal dust and peanut oil as good fuels...
Now there's a challenge - get a 1.9TD running on coal!
2 stroke
- x 1987
Re: 2 stroke
- x 8309
Re: 2 stroke
Stickyfinger wrote:Easy on the 1.6ltr C5, just scrape off the bits from the injectors/turbo feed/valve and feed it back inCitroJim wrote:The Bosch 1.9TD is great like that. If it can be pumped and is vaguely ignitable by compression then its happy...KP wrote:Stu I've run so much horrid stuff thru 1.9tds over the years I was surprised they still ran when I sold them! Straight unfiltered waste veg, engine oil that was horrid, lhm, brake fluid, trams fluid....
KP
- x 27
Re: 2 stroke
Don't even do that, just run one on normal Citroen servicing
xantiagreen
Re: 2 stroke
Your car's a 2SO junkie "500ml", how did it react..... was it fully synthetic?chinkostu wrote:I accidentally managed to dump a whole 500ml in the last tank as i was tipping it in, it didn't glug just gushed out of the bottle!!
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
xantiagreen
Re: 2 stroke
Try Mary Berry she's an expert at sifting..
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
Zelandeth
- x 1592
Re: 2 stroke
Well today I found myself thinking that the Xantia was sounding more clattery, especially at idle than normal. After a few minutes the penny dropped, I fuelled up a couple of days back and forgot to stick the usual splash of 2-stroke oil in, didn't I.
Stuck it in today, and next time the car went out it seemed to be back to what I have come to expect as normal.
So it definitely does seem to make some difference!
Current fleet:
- x 8309
doctle
- x 225
Re: 2 stroke
In my opinion this is homoeopathy for cars. Its a 3000 - 1 dilution, too small to make a difference. I tried similar idea with whiskey and water and it didn't work.
Oh buggle
Zelandeth
- x 1592
Re: 2 stroke
I'd definitely agree based on the logic of it! If you'd suggested the idea to me I'd have discounted it save for the fact a few folks I trust said it helped their cars, so thought I'd give it a try for a few quid given it wasn't going to hurt.
Reckon my test for placebo effect is going to be me getting my other half to add (or not) the 250-300ml I usually stick in the tank for the next few fills and keep a tally of whether I'm right. Random number generator will be used to determine if it gets the oil or not.
...given a tank lasts me a month or two sadly this will take a while.
Current fleet:
daviemck2006
- x 496
Re: RE: Re: 2 stroke
Was that 3000 parts whisky to 1part water lol. NB scotch whisky, none of your Yankee or Irish whiskey here [emoji13] [emoji12] [emoji23] [emoji23]doctle wrote:In my opinion this is homoeopathy for cars. Its a 3000 - 1 dilution, too small to make a difference. I tried similar idea with whiskey and water and it didn't work.
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
doctle
- x 225
Crack at the Mick eh? I nearly choked on my Glenfiddich! Of course technically Bushmills Whiskey is made in Northern Ireland and would therefore be a UK whiskey, E and all! Anyway I digress, my experiment wasn't very well set up. You get a decent size glass say 1/3 of a pint and put your index finger in up to the web. Add water until the tip of your finger is wet and add 1/4 teaspoon of alcohol. It still looks and tastes like water. Doing it the other way about you get what used to be called a fingers length of whiskey. (I like bourbon too, Makers Mark is Kentucky whisky)daviemck2006 wrote:Was that 3000 parts whisky to 1part water lol. NB scotch whisky, none of your Yankee or Irish whiskey here [emoji13] [emoji12] [emoji23] [emoji23]doctle wrote:In my opinion this is homoeopathy for cars. Its a 3000 - 1 dilution, too small to make a difference. I tried similar idea with whiskey and water and it didn't work.
Oh buggle
doctle
- x 225
Re: 2 stroke
Years ago the old diesel heads said to add a pint of petrol to half a tank of diesel every month to burn carbon and clean injectors. I still do it but more out of habit than belief!
Oh buggle
