Pipe order in ABS block
KennyW
x 164
Unread post by KennyW »
Does anyone have the a daigram which shows the position of the various brake pipes fit into the ABS block
Kenny
C3 1.4 petrol (SWMBO)
x 8330
Re: Pipe order in ABS block
I may have Kenny but not in a position at the moment to check my documentation... I'll look later if that's PK. Hopefully I will be have more or less what I had for you last time.
x 6955
Kenny - Until Jim has access, I've dug this out - is this what your looking for? Don't have your VIN so looked this up on a 2.0 HDI 90 BHP Xantia.
x 8330
Hi Kenny,
I've had a look all through my manuals and nowhere can I find a diagram or text that says where each port of the ABS block goes to...
Sorry... It's going to need someone with an S2 to have a look and see...
x 6955
Or this....
x 8330
That looks good Marc :D Excellent...
x 6955
Got there in the end! Killing time as UPS failed to deliver my new Lexia kit after saying nobody was in! They are the worst couriers ever.
x 8330
That's a shame Marc... I've had that nearly happen awhile back. Bloody courier didn't even try and seemed to assume I wasn't in. It was only that I spotted him first that I got my parcel..
Hope the next delivery attempt will be more successful...
x 6955
Cheers Jim - already had a rant at their office - no card left (because he hadn't been). :^o Promised a call back - still waiting an hour later. Quicker to go to Beijing myself :evil:
KennyW
x 164
Thanks for the replies,
I have the diagrams from service Citroen myself but no where is the order of fitting
I know the rear brake supply is bottom left and 2 front supply are above and the 2 3.5mm pipes supplying the doseur are on the right.
I suspect the order is important hopefully the front will resolve itself because there is a significant difference in length.
IF anyone can look at the S2 and abs block and follow the pipes I would be grateful.
It's not raining so I'm going to refit sub frame today. :-D
