Antifreeze ( coolant)
froggy
- (Donor 2026)
- x 4
Hi, just about to change the coolant in the cars. which is the preferred choice , red or blue coolant, many thanks in advance Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
superloopy
- x 19
Re: Antifreeze ( coolant)
My 95 TD is blue if its any help.
Sent from my LG-D855 using Tapatalk
Mike
- x 8329
Blue (ethylene glycol) always in an older engine that currently has blue. To change to a red OAT based one needs a full flush first as the two don't mix... Mixing the two can have quite dire consequences...
froggy
- (Donor 2026)
- x 4
Hi Jim, probably a silly question but what would happen if you mixed the two ? Terry.
Terry
- x 3302
Probably an acidic syrup!
- x 1485
Allegedly the two can create a gel, which would cause a few problems in the system...
Note both are ethylene glycol for antifreeze effect - the difference is in the corrosion inhibitors.
Zelandeth
- x 1592
Apparently when the two mix the corrosion inhibitors react with each other which produces a hard crystalline sediment which enjoys doing things like wrecking water pump bearings and blocking thermostats.
Xantias originally had the old green/blue type coolant I believe.
Either are safe to use though, just bear in mind that if you're changing you'll want to do a good thorough flush first.
My 1989 Saab 900 has been running red OAT coolant for five year or so now (it's what I had on hand when I changed it) and there have been no problems whatsoever as a result - just flush first and you should be fine.
Current fleet:
froggy
- (Donor 2026)
- x 4
cheers
Terry
BX
- x 19
There is also a yellow antifreeze which is compatible with both of the other types. It is very useful for when you do not know what is in there already and you need to top up. Its life span depends on what other type it is mixed with.
xantiagreen
Oh no that's dangerous that is, you'd end up with a mutation something along the lines of flubber, I think Citrojim has some forming in the bottom of his batch of LHM...froggy wrote:Hi Jim, probably a silly question but what would happen if you mixed the two ? Terry.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
Jaf
- x 42
Can I still use Forte stop leak with red antifreeze? I just bought some...so glad I read this thread!
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
- x 8329
Yes, it's (as far as I know) compatible with all types of coolant.
