Subframe removal
KennyW
x 165
Subframe removal
Unread post by KennyW »
Hi All,
I've started to dismantle the car to get subframe out no issues but How to question :?:
How do you access the bolt on which secures the gear linkage to subframe, the access is poor.
Kenny
C3 1.4 petrol (SWMBO)
KennyW
x 165
Re: Subframe removal
Well success subframe off, I didn't find it a hard job but awkward.
Had to remove the safety valve with the angle grinder but this is not savageable rusted up bad. Only the four pipes on the safety valve to replace but with more space I'm checking over the other pipes and may change others if signs of rust.
The weather has intervened so will have to wait to end of the week to continue.
Kenny
x 8365
Well done Kenny!
KennyW
x 165
Has anyone got a break down diagram for the safety valve as I have managed to remove the pipe ends from the unit.
Kenny
KennyW
x 165
Well folks I have got the subframe back on, now for the piping.
Question Does anybody have a photo or diagram of the route of the pipes for the power steering pinion ?
As I'm waiting on the final 2 pipes to arrive and the hydraflush
A big shock today NO rain!!!!!!!!
Kenny
KennyW
x 165
I've trying to find a very good french site for the Xantia repair instructions. Found it again link below.
http://xantia.voila.net/index.html
Worth a look and help improve your french !!!!!!!!!!!!
VertVega
x 13
Unread post by VertVega »
KennyW wrote:I've trying to find a very good french site for the Xantia repair instructions. Found it again link below.
This link was given in Handy Hints & Tips --> Xantia How to do almost anything
Tip: You can use Google Translate (French->English).
Still looking for a similar link for C5 ....
KennyW
x 165
I knew I seen it somewhere!!!!!!!!!!!!!
KennyW
x 165
Well I've fitted all the pipes apart from the brake pipes onto the car.
Awaiting the other pipes and fill up the system.
x 8365
Looking forward to the start-up and hearing all is now good Kenny :D
KennyW
x 165
Hi All,
Well it appears one of the original pipes has been damaged when fitting in the factory and will not screw on (jumping off thread). Block connector not damaged.
Going to get M7 x 1 mm die and try to rethread same other wise pipe off and replace with new.
Going to fit all the other pipes at height corrector and refit brake cables.
Hopefully evrything will go well.
Kenny
PS The french turoial site found by vert verga has closed down possibly by Orange France.
x 8365
That's a bit of a headache Kenny.. Hope the die works.. It should do.. M7 is an odd size. I trust you can find a source. eBay worked for me when I needed an M7 tap...
KennyW
x 165
Well rebuild complete and no leaks so far.
But 2 problems
1. Unfortunately I had to move the clamp on anti roll bar to fit onto dog bone and has knock height out. I can't seem to set the ride height :?:
2. the stop light and temp light is flashing, what causes this :?:
Kenny
x 8365
Excellent Kenny, just minor problems :D
The adjustment of the height corrector is unbelievably critical. With the dogbone off will the front go high and low on the lever? If s then you know the hydraulics are basically OK.
The Stop and temperature light being on is normally a problem with the Brown BITRON sensor on the thermostat housing or the BITRON ECU that controls the cooling fans. Check the connections to both in the first instance...
KennyW
x 165
Thanks Jim,
Fixed height problem it was the height lever rod would appear to have been stuck a quick wiggle and it worked.
I must admit when I started the car the fan came on straight away but I wasn't thinking about the sensors.
Jim can confirm if the HDi has a brown sensor. I know my TD did.
The other piece of good news the normal bubble flares are working fine but I think if they are over tightened there will be leaks.
Kenny
