Lower suspension joint/bearing made my car do that.....later I got a "click" on tight corners at low speed.
I felt unhappy with the steering (felt loose) for weeks and kept saying there was something wrong (even if it had just past it's MOT).
They had collapsed totally.
Should I change my spheres?
- x 1994
Re: Should I change my spheres?
waynedance
- x 8
What bearings do you mean, front lower ball joints? Are there any top suspension mount bearing like on regular spring cars?
Sent from my LG-H815 using Tapatalk
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
Old-Guy
- x 26
I think Alasdair does indeed mean the hub ball-joints.
There are no top suspension bearings, the whole strut outer and hub rotates about the inner strut shaft which does not rotate. The top of the strut shaft is supported by the infamous Xantia Strut Top/Mount, these do give trouble but not with the symptoms you describe.
waynedance
- x 8
May change the ball joints as they are not expensive. I have the tool somewhere to remove them.
Do not here any knocking down pot holes like you would think if the ball joints had excessive play.
- x 1994
Yes I do....sorry my terms got all mixed up.
I had no knocks either, just a "loose feeling) on changing direction then later the click and it looked like this when it came apart.
I have drive American cars (new ones btw ! ) with worse steering than this had in this state
http://www.frenchcarforum.co.uk/forum/v ... ts#p439219
waynedance
- x 8
Not got thoses on C5?
Old-Guy
- x 26
From the service.citroen parts diagram the C5 has a fairly conventional bottom swivel ball joint that appears to screw into the hub. It looks as though a special tool is needed to undo/tighten this.
waynedance
- x 8
Got the ball joints and tool will fit this week.
- x 1994
Ahh....not an x7 type....then yes,the same screw in ball type.
waynedance
- x 8
Not long now until the 6 new spheres arrive.
How hard is the front middle one to change? Looks tight.
