C5 Rear Arm Bearings
x 3281
Re: C5 Rear Arm Bearings
Well, when I asked Citronut (may he rest in peace) what he would suggest, he told me he normally packs them out with Moly Grease (to massively extend the life of the bearings).
hamster99
Unread post by hamster99 »
Old-Guy wrote:
hamster99 wrote:What is the plastic tube in the middle for? Doesn't seem to serve any purpose as far as I can tell, other than to make it more difficult to drift the bearings out.
The service citroen site calls it a seal protector but the seals are on the outside, not inside the arm!!
Could it just be a cheap/lightweight method of filling the space to reduce the volume of grease needed to pack the bearings adequately?
I think you're probably right...........
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
hamster99
Drivers side all sorted, all back together nicely............however.........passenger side proving to be a PITA.
Have undone everything but the suspension connecting rod at the end of the gaiter where it fits into the trailing arm is just seized solid.
Have plus gassed it, hammered it, levered it and it wont budge at all!!!
Does anyone know if the connecting rod is attached to the piston in the suspension cylinder or is it possible to remove it and take it out with the trailing arm without getting LDS everywhere.
I'm sure I could get it out when its off the car.
Sometimes I wonder if it would have been easier to take it to the garage...!!!
hamster99
Re: C5 Rear Arm Bearings - GETS WORSE........!!!!
Well, trailing arm now off the car but things are getting worse in that the outer bearing had completely destroyed itself with the taper bearings liberally scattered about and seeming to have made the hole in the arm rather more oval than round.
Looks like I may have to replace the whole arm............rather annoyingly I only had my old C5 taken away a few months ago.....typical....!!!
Now I have to find an arm........anybody breaking a C5...?????
Or can point me in the direction of a decent breakers who would have one.
Rob
x 5615
Whereabouts are you Rob - can make a big difference in the recommendations for scrapyards.
Malcolm (citronut) knew of a good one. I'll see if I can find it.
x 5615
citronut wrote:have you asked
http://www.pcr767676.co.uk/" onclick="window.open(this.href);return false;
as they are Cit Pug specialist dismantlers ,
or give
G.M Woodgate & Son
Potteries
Further Quarter
High Halden
Ashford
Kentd
TN26 3HX
Tel: 01233 850303
this lot are a very very friendly/helpful bunch,
the yard is like going back in time 20 or 30 years
as you can climb over the cars, stomp through the muddy troughs there tractor had mad, its a GREAT scrap yard dont get many like that any more
plus they dont charge high prices either
hamster99
Finally managed to get a replacement rear arm, installed new bearings etc and now ready to stick it on the car.
However, the pushrod that sits in the suspension cylinder fits into a socket on the arm itself but fell out rather easily when I took the arm off the donor car. Fine I thought, it will, just go back in but no, it seems to be like one of those impossible metal puzzles.
No matter what angle I place the pushrod at, the end won't go into the socket...!!!
Anybody suggest a way to do this? I don't want to try brute force and break it, especially as it came out so easily on its own...!!!
john 1952
Unread post by john 1952 »
if you loosen the bleed screw at center of axle, you should be able to push rod into cylinder, then tighten bleed screw again !
