Davie's french attraction.
- x 3298
Re: Davie's french attraction.
daviemck2006
- x 485
I'm working through the jobs on the 205. This was prompted by a must look at it now problem of a front brake sticking on. Thankfully I was less than 1/2 mile from home. The pads and discs look very recent, in miles anyway, goodness knows how much time lol. There was not a drop of grease anywhere the pads, so all removed cleaned and refitted. Engine oil and filter changed, I have just used cheap tesco stuff, I will give it 1000 miles then flush it and change it again, and fit a new sump, it is very rusty and felt a bit weak when taking off the drain plug. Air filter and plugs like new. Just the driveshaft boot to change, it's still jacked up on axle stands yet. The other expense it needs is 4 new tyres. Out of the five, two are Michelin mxt which I think would be original 1995 made, no date code, bad perishing on the side walls. Three Falkenham with a date code of 2102. One has about 5 mm on the back, and is ok, two fronts about 3mm, slight perishing probably legal but very pathetic grip in the wet. There is a set of 14" gti wheels with my name on them coming this way! However I would rather keep the originality of the car and have steels and trims, but the trims are knackered and the wheels seriously rusty so undecided yet.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
daviemck2006
- x 485
Well after a week of resting after putting my back out. The driveshaft boot is done, and I drained the gearbox and treated it to new oil. Mot booked for Thursday next week. I have a feeling it's going to need new brake pipes, they look a bit crusty. It's going to get new brake fluid anyway so I will wait until after the mot. I will also drain and flush the cooling system. I think after 11 years of only doing 1500 miles a year a bit of tlc won't go wrong. The cooling system will get done while it gets a cambelt and water pump. Then it should be in tip top condition.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
- x 8440
Davie, delighted to hear your back has recovered enough to be able to do the boot and oil. Excellent
All the best with the MoT
daviemck2006
- x 485
The renault threw it's toys out on Saturday night. For a couple of weeks it has been randomly setting off its alarm. I was in Aberdeen to a function on Saturday and at midnight it wouldn't start. Called out the AA, tested battery, it had 12.1 volts. Jump started it, alternator putting out 14.5. So I'm waiting for them to come to the house, as it won't start again, I will get a new battery for a £35 excess on my breakdown repair cover. I am now assuming that renaults are as bad as Citroens for needing a battery in top condition. It's maybe just modern cars, lose 1/2 a volt and the car takes a hissy fit!
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
- x 8440
It seems so but it's silly. You'd have thought modern automotive electronics would have been deliberately designed to work at a low - say 6V - voltage and regulate this from the nominal 12v battery supply. Then a failing battery would not upset the electronics so badly. It seems fundamental to me but then I'm most likely missing something significant heredaviemck2006 wrote: It's maybe just modern cars, lose 1/2 a volt and the car takes a hissy fit!
daviemck2006
- x 485
That's new battery fitted. Now starts the hunt to see if I have the radio code! Martin, the local AA man, who I am on first name terms with after the fiesta, says they used to call them renault migrane they suffer so many electrical faults! He did say it's more likely to be diesels with electric handbrakes that were the worst and 1.4 and 1.6 petrol weren't bad cars.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
- x 5679
This!CitroJim wrote:It seems so but it's silly. You'd have thought modern automotive electronics would have been deliberately designed to work at a low - say 6V - voltage and regulate this from the nominal 12v battery supply. Then a failing battery would not upset the electronics so badly. It seems fundamental to me but then I'm most likely missing something significant heredaviemck2006 wrote: It's maybe just modern cars, lose 1/2 a volt and the car takes a hissy fit!
Most off the shelf electronics seem to prefer 5V anyway.
daviemck2006
- x 485
Small hole in boot floor, both front flexi brake hoses perished, both front bottom ball joints worn. Not bad for a 20 year old.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
- x 8440
That's not bad at all Davie, all things considered...
Consider yourself lucky it's not the flexi hose on the rear beam. Access is a tad 'interesting'...
Are you doing any of it yourself or entrusting it?
daviemck2006
- x 485
I've just booked it in to get the welding done and away to order the flexi pipes, only like 7 quid for pagid ones and complete bottom arms. I will do them myself, I think the weather is going to be better next week, and got 14 days to get it done. It will be a fine chance to change the brake fluid, which I wanted to do anyway.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
daviemck2006
- x 485
£58 of parts ordered.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
daviemck2006
- x 485
After 3 years of not working, I start a little part time job on Monday. A fast food delivery driver for a newly taken over chip shop which is branching out into all sorts of cuisine and starting home delivery. I will only be part time, and earliest start 4 pm and latest finish 10 pm. Using own car so just as well I have 2, incase one breaks! I will see how if goes, if things go ok I can see the need for the renault leaving my custody and a diesel that will run on wvo [emoji4]
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
- x 2006
Large portion of cod nd chips please, not paying if it takes you more than 1 hour ...
daviemck2006
- x 485
Hmmmmmmm I think I will need more than a £3 local delivery for that [emoji13]Stickyfinger wrote:Large portion of cod nd chips please, not paying if it takes you more than 1 hour ...
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
